3359|4
854
wince 的fatutil.dll 有什么用? [复制链接]
fatutil.dll 这个看有些人实现多fat 分区会用到这个dll ,在SLC nandflash 上,我现在要做这个功能,但是行不通,这个fatutil.dll 什么用的?
个人签名如果对linux,Android,wince 等嵌入式底层有兴趣的,请加这个QQ群吧,群号:27100460
854
似乎是格式化分区的
WinCE下SD卡格式化代码
如下代码经本人改写并验证成功。
注意:需要用到微软的API库"Storeapi.lib"和“storemgr.lib”。
#include "stdafx.h"
#include
#include
#include
#include
#include
#include
//#include
//#include
int wmain()
    STOREINFO StoreInfo = {0};
    PARTINFO PartInfo = {0};
    HANDLE hFirstStore,hStore,hPart;
    HINSTANCE hFatUtil = NULL;
    BOOL hDismount = FALSE;//, CPart,hPartition,
    BOOL hMount = FALSE;
    FORMAT_PARAMS fp = {0};
    FORMAT_OPTIONS pfo = {0};
    DWORD dwClusSize = 0;
    DWORD dwFatVersion = 16;
    typedef DWORD ( *PFN_MY_FORMATVOLUME)
        (HANDLE hVolume,PDISK_INFO pdi, PFORMAT_OPTIONS pfo, PFN_PROGRESS pfnProgress,PFN_MESSAGE pfnMessage);
    StoreInfo.cbSize = sizeof(StoreInfo);
    hFirstStore = FindFirstStore( &StoreInfo );
    if(!(hFirstStore ))
        RETAILMSG(1, (TEXT("Error FindFirstStore\r\n")));
    FindNextStore(hFirstStore,&StoreInfo);
    hFatUtil = LoadLibrary(L"fatutil.dll");
    PFN_MY_FORMATVOLUME pfnFormatVolume = NULL ;
    pfnFormatVolume = (PFN_MY_FORMATVOLUME)GetProcAddress(hFatUtil, TEXT( "FormatVolume"));
    if (!pfnFormatVolume )
        RETAILMSG(1, (TEXT("Error pfnFormatVolumeEx\r\n")));
    hStore = OpenStore(StoreInfo.szDeviceName);
    hPart = OpenPartition(hStore,L"Part00");
    hDismount = DismountPartition(hPart);
    if(!hDismount)
        RETAILMSG(1, (TEXT("Error DismountStore\r\n")));
    if(ERROR_SUCCESS != pfnFormatVolume(hPart, NULL, NULL, NULL, NULL))
    PartInfo.cbSize = (DWORD)StoreInfo.snBiggestPartCreatable;
    //PartInfo.szPartitionName = L"Part00";
    hDismount = CreatePartition(hStore, L"Part00", PartInfo.cbSize);
    if(!hDismount)
        RETAILMSG(1, (TEXT("Error CreatePartitionEx\r\n")));
    hMount = MountPartition(hPart);
    if(!( hMount ))
        RETAILMSG(1, (TEXT("Error OpenStore\r\n")));
return 0;
本文参考自http://bbs.driverdevelop.com/htm_data/48/0711/107241.html
854
[HKEY_LOCAL_MACHINE\System\StorageManager\FATFS]
    "FriendlyName"="FAT FileSystem"
    "Dll"="exfat.dll"
    "DisableAutoFormat"=dword:1
    "DisableAutoScan"=dword:1
    "Paging"=dword:1
    "EnableCache"=dword:1
    "CacheSize"=dword:0
    "Util"="fatutil.dll"
    "CacheDll"="diskcache.dll"
; @CESYSGEN IF CE_MODULES_CACHEFILT
[HKEY_LOCAL_MACHINE\System\StorageManager\FATFS\Filters\CacheFilt]
    "Dll"="cachefilt.dll"
    "LockIOBuffers"=dword:1
; @CESYSGEN ENDIF CE_MODULES_CACHEFILT
[HKEY_LOCAL_MACHINE\System\StorageManager\EXFAT]
    "FriendlyName"="exFAT FileSystem"
    "Dll"="exfat.dll"
    "Paging"=dword:1
    "CacheSize"=dword:0
    "FormatExfat"=dword:1
wince common.reg 里面 有这个使用方法,看来对我有用,下班先了。明天再来尝试一下。
854
854
; @CESYSGEN IF CE_MODULES_FATUTIL
   fatutil.dll     $(_FLATRELEASEDIR)\fatutil.dll              NK  SHQ
; @CESYSGEN ENDIF
确认这个是否打包进去了。
