7595|0
367
裸片初长成(高级)
[转帖]AVR驱动软驱电机程序 [复制链接]
/*用mega32三个口线驱动软驱电机. PA2接LB1833 ENA1\2 脚; PA1接LB1833 IN1 脚; PA0接LB1833 IN2 脚. *************************************************** / //ICC-AVR application builder : 2005-5-20 10:40:30 // Target : M32 // Crystal: 3.6864Mhz #include #include unsigned char np; //步进电机运行数据表 const unsigned char motortb[]={0x05,0x07,0x06,0x04,0x05,0x07,0x06,0x04}; void delay ( unsigned char t );// 每步延时的子程序 void a_step( unsigned char d, unsigned char t );//步进电机走一步d=0 正转d=1 反转 void port_init( void ) { PORTA = 0x00; DDRA = 0xFF; PORTB = 0xFF; DDRB = 0x00; PORTC = 0xFF; DDRC = 0x00; PORTD = 0xFF; DDRD = 0x00; } //call this routine to initialise all peripherals void init_devices( void ) { //stop errant interrupts until set up CLI(); //disable all interrupts port_init(); MCUCR = 0x00; GICR = 0x00; TIMSK = 0x00; //timer interrupt sources SEI(); //re-enable interrupts //all peripherals are now initialised } void delay ( unsigned char t )// 每步延时的子程序 { unsigned char i; unsigned int j; for (i = 0 ; i < t ; i++ ) { for ( j = 0 ;j < 800 ; j++ ) ; } } void a_step ( unsigned char d, unsigned char t) //步进电机走一步d=0 正转d=1 反转 t // 越大走得越慢 { if ( d & 0x01 ) { if ( np == 0 ) { np = 7; } else { np--; } } else { if ( np == 7 ) { np = 0; } else { np++; } } PORTA = motortb[np]; delay(t); } void a_turn (unsigned char d, unsigned char t)// 步进电机走一圈 { unsigned char i; for ( i = 0 ; i < 96 ; i++ ) { a_step ( d, t ); } } void main ( void ) { np = 4; while (1) { a_turn ( 1, 1 ); } } /****************************/
