2983|1
484
在Tiva LauchPad上测试PWM程序 [复制链接]
在PD0输出PWM信号,每隔一秒反相一次
#include
#include
#include "inc/hw_memmap.h"
#include "driverlib/gpio.h"
#include "driverlib/pin_map.h"
#include "driverlib/pwm.h"
#include "driverlib/sysctl.h"
#include "driverlib/uart.h"
#include "utils/uartstdio.h"
//! \addtogroup pwm_examples_list
PWM Invert (invert)
//! This example shows how to setup PWM0 using the inverted output function.
//! This feature allows you to invert the polarity of the PWM output.  This
//! example is setup to invert a 25% duty cycle to get a 75% duty cycle every
//! 5 seconds.
// This function sets up UART0 to be used for a console to display information
// as the example is running.
void
InitConsole(void)
    // Enable GPIO port A which is used for UART0 pins.
    // TODO: change this to whichever GPIO port you are using.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
    // Configure the pin muxing for UART0 functions on port A0 and A1.
    // This step is not necessary if your part does not support pin muxing.
    // TODO: change this to select the port/pin you are using.
    GPIOPinConfigure(GPIO_PA0_U0RX);
    GPIOPinConfigure(GPIO_PA1_U0TX);
    // Enable UART0 so that we can configure the clock.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
    // Use the internal 16MHz oscillator as the UART clock source.
    UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC);
    // Select the alternate (UART) function for these pins.
    GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
    // Initialize the UART for console I/O.
    UARTStdioConfig(0, 115200, 16000000);
// Configure PWM0 for a 25% duty cycle signal running at 250Hz.  This example
// also shows how to invert the PWM signal every 5 seconds for 5 seconds.
int
main(void)
    // Set the clocking to run directly from the external crystal/oscillator.
    // TODO: The SYSCTL_XTAL_ value must be changed to match the value of the
    // crystal on your board.
    SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                   SYSCTL_XTAL_16MHZ);
    // Set the PWM clock to the system clock.
    SysCtlPWMClockSet(SYSCTL_PWMDIV_1);
    // Set up the serial console to use for displaying messages.  This is
    // just for this example program and is not needed for Timer operation.
    InitConsole();
    // Display the setup on the console.
    UARTprintf("  PWM ->\n");
    UARTprintf("  模块: PWM1\n");
    UARTprintf("  引脚: PF2\n");
    UARTprintf("  配置占空比: 25%%\n");
    UARTprintf("  反相占空比: 75%%\n");
    UARTprintf("  功能: PWM输出每隔1秒反相一次.\n\n");
    UARTprintf("  在M1PWM6(PF2)上产生PWM信号 -> 状态 = ");
    // The PWM peripheral must be enabled for use.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM0);
    // For this example PWM0 is used with PortB Pin6.  The actual port and
    // pins used may be different on your part, consult the data sheet for
    // more information.
    // GPIO port B needs to be enabled so these pins can be used.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
    // Configure the GPIO pin muxing to select PWM00 functions for these pins.
    // This step selects which alternate function is available for these pins.
    // This is necessary if your part supports GPIO pin function muxing.
    // Consult the data sheet to see which functions are allocated per pin.
    GPIOPinConfigure(GPIO_PB6_M0PWM0);
    // Configure the PWM function for this pin.
    GPIOPinTypePWM(GPIO_PORTB_BASE, GPIO_PIN_6);
    // Configure the PWM0 to count up/down without synchronization.
    PWMGenConfigure(PWM0_BASE, PWM_GEN_0, PWM_GEN_MODE_UP_DOWN |
                    PWM_GEN_MODE_NO_SYNC);
    // Set the PWM period to 250Hz.  To calculate the appropriate parameter
    // use the following equation: N = (1 / f) * SysClk.  Where N is the
    // function parameter, f is the desired frequency, and SysClk is the
    // system clock frequency.
    // In this case you get: (1 / 250Hz) * 16MHz = 64000 cycles.  Note that
    // the maximum period you can set is 2^16.
    // TODO: modify this calculation to use the clock frequency that you are
    // using.
    PWMGenPeriodSet(PWM0_BASE, PWM_GEN_0, 64000);
    // Set PWM0 to a duty cycle of 25%.  You set the duty cycle as a function
    // of the period.  Since the period was set above, you can use the
    // PWMGenPeriodGet() function.  For this example the PWM will be high for
    // 25% of the time or 16000 clock ticks (64000 / 4).
    PWMPulseWidthSet(PWM0_BASE, PWM_OUT_0,
                     PWMGenPeriodGet(PWM0_BASE, PWM_OUT_0) / 4);
    // Enable the PWM0 Bit0 (PD0) output signal.
    PWMOutputState(PWM0_BASE, PWM_OUT_0_BIT, true);
    // Enable the PWM generator block.
    PWMGenEnable(PWM0_BASE, PWM_GEN_0);
    // Loop forever while the PWM signals are generated.
    while(1)
        // Print out that the level of PWM is normal.
        UARTprintf("Normal  \b\b\b\b\b\b\b\b");
        // This function provides a means of generating a constant length
        // delay.  The function delay (in cycles) = 3 * parameter.  Delay
        // 5 seconds arbitrarily.
        SysCtlDelay((SysCtlClockGet() * 1) / 3);
        // Invert PWM0 signal.
        PWMOutputInvert(PWM0_BASE, PWM_OUT_0_BIT, true);
        // Print out that the level of PWM is inverted.
        UARTprintf("Inverted\b\b\b\b\b\b\b\b");
        // Switch PWM0 signal back to regular operation.
        PWMOutputInvert(PWM0_BASE, PWM_OUT_0_BIT, false);
在LauchPad评估板上的测试结果:
[ 本帖最后由 平湖秋月 于 2013-12-5 01:05 编辑 ]
484
推荐
呵呵,现在怎么连贴图功能都取消了?
现在怎么连贴图功能都取消了?
