2888|4
5310
453
TIVA C Launchpad (EK-LM4F120XL LaunchPad)让LED闪起来! [复制链接]
根据LB4教程,使用定时器中断,使GPIOF口连接的LED闪起来!
添加相关头文件
#include "driverlib/interrupt.h"
#include "driverlib/timer.h"
#include "driverlib/systick.h"
主程序
1、配置系统时钟
2、使能LED连接端口,配置输出
3、配置定时器0,1,W0,都为周期触发!
4、使能全局中断
5、使能定时器中断
int
main(void)
    long  Period;
    // The FPU should be enabled because some compilers will use floating-
    // point registers, even for non-floating-point code.  If the FPU is not
    // enabled this will cause a fault.  This also ensures that floating-
    // point operations could be added to this application and would work
    // correctly and use the hardware floating-point unit.  Finally, lazy
    // stacking is enabled for interrupt handlers.  This allows floating-
    // point instructions to be used within interrupt handlers, but at the
    // expense of extra stack usage.
    FPUEnable();
    FPULazyStackingEnable();
    // Set the clocking to run directly from the crystal.
    //配置系统时钟 16M
    ROM_SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ);
    // Enable the peripherals used by this example.
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
    ROM_GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE,GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3);
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);
    ROM_TimerConfigure(TIMER0_BASE, TIMER_CFG_PERIODIC);
    Period=(ROM_SysCtlClockGet()/10)/2;
    ROM_TimerLoadSet(TIMER0_BASE, TIMER_A, Period-1);
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER1);
    ROM_TimerConfigure(TIMER1_BASE, TIMER_CFG_PERIODIC);
    ROM_TimerLoadSet(TIMER1_BASE, TIMER_A, ROM_SysCtlClockGet() / 1);
        ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_WTIMER0);// 使能宽64位定时器0外设
        ROM_TimerConfigure(WTIMER0_BASE,TIMER_CFG_PERIODIC);//配置64位宽的定时器0
        ROM_TimerLoadSet64(WTIMER0_BASE,ROM_SysCtlClockGet()/1);
    // Enable processor interrupts.
    ROM_IntMasterEnable();
    // Setup the interrupts for the timer timeouts.
    ROM_IntEnable(INT_TIMER0A);
    ROM_IntEnable(INT_TIMER1A);
        ROM_IntEnable(INT_WTIMER0A);//使能64位宽的定时器0中断
    ROM_TimerIntEnable(TIMER0_BASE, TIMER_TIMA_TIMEOUT);
    ROM_TimerIntEnable(TIMER1_BASE, TIMER_TIMA_TIMEOUT);
        ROM_TimerIntEnable(WTIMER0_BASE,TIMER_TIMA_TIMEOUT);
    // Enable the timers.
    ROM_TimerEnable(TIMER0_BASE, TIMER_A);
    ROM_TimerEnable(TIMER1_BASE, TIMER_A);
        ROM_TimerEnable(WTIMER0_BASE,TIMER_A);//使能64位宽的定时器0
    // Loop forever while the timers run.
    while(1)
5310
453
定时器0中断
// The interrupt handler for the first timer interrupt.
void
Timer0IntHandler(void)
        static unsigned char i=0;
    // Clear the timer interrupt.
    ROM_TimerIntClear(TIMER0_BASE, TIMER_TIMA_TIMEOUT);
    if(i==0)
            i=1;
            ROM_GPIOPinWrite(GPIO_PORTF_BASE,GPIO_PIN_2,0);
    else
    {        i=0;
            ROM_GPIOPinWrite(GPIO_PORTF_BASE,GPIO_PIN_2,4);
5310
453
定时器1中断
// The interrupt handler for the second timer interrupt.
void
Timer1IntHandler(void)
{static unsigned char i=0;
    ROM_TimerIntClear(TIMER1_BASE, TIMER_TIMA_TIMEOUT);
    if(i==0)
                i=1;
                ROM_GPIOPinWrite(GPIO_PORTF_BASE,GPIO_PIN_3,0);
        else
        {        i=0;
                ROM_GPIOPinWrite(GPIO_PORTF_BASE,GPIO_PIN_3,8);
5310
453
宽定时器0中断
void
WTimer0IntHandler(void)
    ROM_TimerIntClear(WTIMER0_BASE,TIMER_TIMA_TIMEOUT);
    if(i==0)
                i=1;
                ROM_GPIOPinWrite(GPIO_PORTF_BASE,GPIO_PIN_1,0);
        else
        {        i=0;
                ROM_GPIOPinWrite(GPIO_PORTF_BASE,GPIO_PIN_1,2);
5310
453
修改startup_ccs.c文件
函数声明
extern void Timer0IntHandler(void);
extern void Timer1IntHandler(void);
extern void WTimer0IntHandler(void);
修改向量表函数
Timer0IntHandler,                      // Timer 0 subtimer A
    IntDefaultHandler,                      // Timer 0 subtimer B
    Timer1IntHandler,                      // Timer 1 subtimer A
    IntDefaultHandler,                      // Timer 1 subtimer B
WTimer0IntHandler,                      // Wide Timer 0 subtimer A
    IntDefaultHandler,                      // Wide Timer 0 subtimer B
