2587|0
142
TIVA C Launchpad周计划——第三周(5110液晶屏) [复制链接]
用Energia开发环境驱动5110液晶屏,板子上的按键来控制背光的开关,程序是在GitHub上找到的,貌似就是做Energia的人写的,有部分还是用C++写的,还有一些地方没看懂。。。
myScreen.text(0, 2, "LaunchPad")这个函数是用定义的0号字体,在屏幕第二行显示LaunchPad单词,字体和显示行可以自定义,最大字体是2,最多5行 程序还兼容430的launchpad,接线如下
  1. #if defined(__MSP430G2553__) // LaunchPad MSP430G2553 specific
  2. LCD_5110::LCD_5110() {
  3.     LCD_5110(P2_2,    // Chip Select
  4.              P2_4,    // Serial Clock
  5.              P2_0,    // Serial Data
  6.              P2_3,    // Data/Command
  7.              P1_0,    // Reset
  8.              P2_1,    // Backlight
  9.              PUSH2);   // Push Button 2
  10. }
  11. #elif defined(__MSP430G2452__) // LaunchPad MSP430G2452 specific
  12. LCD_5110::LCD_5110() {
  13.     LCD_5110(P2_2,    // Chip Select
  14.              P2_4,    // Serial Clock
  15.              P2_0,    // Serial Data
  16.              P2_3,    // Data/Command
  17.              P1_0,    // Reset
  18.              P2_1,    // Backlight
  19.              PUSH2);   // Push Button 2
  20. }
  21. #elif defined(__LM4F120H5QR__) // StellarPad LM4F specific
  22. LCD_5110::LCD_5110() {
  23.     LCD_5110(PA_7,    // Chip Select
  24.              PA_3,    // Serial Clock
  25.              PA_5,    // Serial Data
  26.              PA_2,    // Data/Command
  27.              PB_5,    // Reset
  28.              PA_6,    // Backlight
  29.              PUSH2);   // Push Button 2
  30. }
  31. #else
  32. #error Platform not supported
  33. #endif
复制代码
  1. // Include application, user and local libraries
  2. #include "LCD_5110.h"
  3. // Variables
  4. LCD_5110 myScreen;
  5. boolean        backlight = false;
  6. uint8_t k = 0;
  7. // Add setup code
  8. void setup() {
  9.     myScreen.begin();
  10.
  11.     myScreen.setBacklight(backlight);
  12.     myScreen.text(0, 0, "Hello!");
  13.
  14.     delay(1000);
  15.     //  myScreen.clear();
  16.     myScreen.text(0, 5, "Light off");
  17. }
  18. // Add loop code
  19. void loop() {
  20.     if (myScreen.getButton()) {
  21.         backlight = (backlight==0);
  22.         myScreen.setFont(0);
  23.         myScreen.text(0, 5, backlight ? "Light on " : "Light off");
  24.         myScreen.setBacklight(backlight);
  25.     }
  26.
  27.     myScreen.setFont(0);
  28.     if (k==0)   myScreen.text(0, 2, "Stellaris");
  29.     else if (k==8)   myScreen.text(0, 2, "LaunchPad");
  30.
  31.     myScreen.setFont(0);
  32.     for (uint8_t i=0; i<14; i++) myScreen.text(i, 4, (i==k) ? "*" : " ");
  33.     k++;
  34.     k %= 14;
  35.
  36.     delay(200);
  37. }
复制代码
