TIVA C Launchpad使用心得二——keil建立新工程 点亮LED
TIVA C Launchpad使用心得二——keil建立新工程 点亮LED 1、建立工程文件夹 2、打开keil软件建立工程文件 3、设置工程属性。 4、编译下载仿真 5、点亮LED //***************************************************************************** #include #include #include "inc/hw_types.h" #include "inc/hw_memmap.h" #include "driverlib/sysctl.h" #include "driverlib/gpio.h" //***************************************************************************** // // Define pin to LED color mapping. // //***************************************************************************** #define RED_LED GPIO_PIN_1 #define BLUE_LED GPIO_PIN_2 #define GREEN_LED GPIO_PIN_3 //***************************************************************************** // The error routine that is called if the driver library encounters an error. // //***************************************************************************** #ifdef DEBUG void __error__(char *pcFilename, uint32_t ui32Line) { } #endif //***************************************************************************** // // Main 'C' Language entry point. Toggle an LED using TivaWare. // tutorial videos. // //***************************************************************************** int main(void) { // // Setup the system clock to run at 50 Mhz from PLL with crystal reference // SysCtlClockSet(SYSCTL_SYSDIV_4|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ| SYSCTL_OSC_MAIN); // // Enable and configure the GPIO port for the LED operation. // SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF); GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED); // // Loop Forever // while(1) { // // Turn on the LED // GPIOPinWrite(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED, RED_LED); // // Delay for a bit // SysCtlDelay(2000000); // // Turn on the LED // GPIOPinWrite(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED, BLUE_LED); // // Delay for a bit // SysCtlDelay(2000000); GPIOPinWrite(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED, GREEN_LED); // // Delay for a bit // SysCtlDelay(2000000); GPIOPinWrite(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED, RED_LED|BLUE_LED|GREEN_LED); // // Delay for a bit // SysCtlDelay(2000000); } } 6、总结,TI的TivaWare是用起来还是非常方便。而且在设置工程属性时,添加include paths只需设置tivaware目录就行,这样 不会感觉有些库文件目录太深。一开始来还是添加分散的头文件比较好,因为可以看到函数的定义等等,熟悉了就直接用 driverlib.lib省事。此外,如果Tivaware能有一个*.chm文件用来帮助查阅库的话就更好了。
