2829|1
38
105
根据体感调节室温和加湿器《贴心保姆》 [复制链接]
无意间又有了个主意,觉得可以拿出来试一试。
将SensorTag佩戴在身上靠近身体的地方;当使用者回到家中时,主控芯片将通过蓝牙读取SensorTag的湿度、温度数据,并与室温和室内湿度相比对,从而向空调和加湿器发出指令进行工作,将室内环境调节到体感最舒服的状态。
这个是根据体温和室温的对比,来智能地调节空调与加湿器设备的。类似的东西不知道是不是已经有人做过了,只不过我没见到而已?我见到的都是以室内气温为准调节的。但刚刚从外面回来,如果按室内温度控制空调等设备的话,肯定不过瘾。热天的时候刚从外面回来,使劲吹吹冷风才舒服,过一会儿热劲退了才会开恒温档。
如果能跟BB-Black一块申请下来就好了,嘿嘿,可以用那个做主控制器,对方案进行远程web界面的自由配置。
共有以下这些情况,根据这些情况做出判断就好:
室温
室内湿度
体温
身体湿度
ok
ok
ok
ok
ok
ok
ok
low
ok
ok
ok
high
ok
ok
low
ok
ok
ok
low
low
ok
ok
low
high
ok
ok
hight
ok
ok
ok
hight
low
ok
ok
hight
ok
ok
low
ok
low
ok
low
ok
high
ok
low
ok
high
ok
low
low
ok
ok
low
low
low
ok
low
low
high
ok
low
hight
ok
ok
low
hight
low
ok
low
hight
high
ok
hight
ok
ok
ok
hight
ok
low
ok
hight
ok
high
ok
hight
low
ok
ok
hight
low
low
ok
hight
low
high
ok
hight
hight
ok
ok
hight
hight
low
ok
hight
hight
high
low
ok
ok
ok
low
ok
ok
low
low
ok
ok
high
low
ok
low
ok
low
ok
low
low
low
ok
low
high
low
ok
hight
ok
low
ok
hight
low
low
ok
hight
ok
low
low
ok
low
low
low
ok
high
low
low
ok
high
low
low
low
ok
low
low
low
low
low
low
low
high
low
low
hight
ok
low
low
hight
low
low
low
hight
high
low
hight
ok
ok
low
hight
ok
low
low
hight
ok
high
low
hight
low
ok
low
hight
low
low
low
hight
low
high
low
hight
hight
ok
low
hight
hight
low
low
hight
hight
high
high
ok
ok
ok
high
ok
ok
low
high
ok
ok
high
high
ok
low
ok
high
ok
low
low
high
ok
low
high
high
ok
hight
ok
high
ok
hight
low
high
ok
hight
ok
high
low
ok
low
high
low
ok
high
high
low
ok
high
high
low
low
ok
high
low
low
low
high
low
low
high
high
low
hight
ok
high
low
hight
low
high
low
hight
high
high
hight
ok
ok
high
hight
ok
low
high
hight
ok
high
high
hight
low
ok
high
hight
low
low
high
hight
low
high
high
hight
hight
ok
high
hight
hight
low
high
hight
hight
high
[ 本帖最后由 tourlet 于 2013-11-4 16:59 编辑 ]
此帖出自无线连接论坛
编程真是伟大啊  详情 回复 发表于 2013-11-13 10:05
编程真是伟大啊
此帖出自无线连接论坛
