2291|5
5015
裸片初长成(初级)
Chronos 个人局域网和传感器节点开发系统 [复制链接]
TI最近推出的一套基于chronos手表的无线系统,我想这是在一定程度上去将MSP430应用于满足穿戴式设备
详细技术文档在此获得:http://www.ti.com.cn/tool/cn/tidm-chronos-pan?DCMP=tidesigns-cn&HQS=tidesigns-mcu-msp-chronos-bhp-cn
技术特点:
This reference design features a highly integrated, wearable wireless development system provided in a sports watch form-factor. It may be used as a reference platform for watch systems, a personal display for personal area networks, or as a wireless sensor node for remote data collection. Based on the CC430F6137 <1 GHz RF SoC, the eZ430-Chronos is a complete CC430-based development system contained in a watch and features a 96 segment LCD display, an integrated pressure sensor and 3-axis accelerometer for motion sensitive control.
特性
  • Complete sports watch based on the CC430F6137, an MSP430™ microcontroller with integrated sub-1-GHz wireless transceiver
  • Watch can be reprogrammed for custom wireless applications
  • Highly integrated watch includes on-board three-axis accelerometer, pressure sensor, temperature sensor, and battery voltage sensor
  • 96-segment LCD display driven directly by the CC430 microcontroller
  • Can be paired wirelessly with heart-rate monitors, pedometers, or other devices based on RF transceivers such as the CC430 or CC11xx devices
  • Includes an eZ430-RF USB emulator that connects the eZ430-Chronos to a PC for real-time in-system programming and debugging.
  • This reference design is tested and includes firmware, hardware design files & documentation.
  • Hardware based on this design is also orderable from the TI eStore (eZ430-CHRONOS)
谁知道哪里有便宜的CC430F5137和6137卖?要尽量接近官方报价吆,淘宝上好像只有30多的  详情 回复 发表于 2013-9-6 08:53
个人签名《MCU工程师炼成记》作者之一
1729
这个不是早就有了吗?跟以前的有区别吗?是新的产品吗?
没有本质区别,只是增加了和手表的互联设备  详情 回复 发表于 2013-9-6 07:59
1453
在犹豫,要不要下手呢
个人签名http://weibo.com/u/1391449055
5015
裸片初长成(初级)
回复 沙发cat3902982 的帖子
个人签名《MCU工程师炼成记》作者之一
5276
裸片初长成(中级)
很多场合也许用蓝牙更好?
5276
裸片初长成(中级)
