2864|4
940
新手求助:官方Lauchpad示例中的中断按按键不起作用 [复制链接]
下载了官方的示例:http://processors.wiki.ti.com/index.php/MSP430_LaunchPad_Drive_LED
  1. //***************************************************************************************
  2. // MSP430 Blink LED / Start Stop Blinking with Button Demo - Software Toggle P1.0 & P1.6
  3. //
  4. // Description; Toggle P1.0 and P1.6 by xor'ing them inside of a software loop. To
  5. // start/stop blink, an interrupt in Port 1 will toggle the condition statement.
  6. // ACLK = n/a, MCLK = SMCLK = default DCO
  7. //
  8. // MSP430x2xx
  9. // -----------------
  10. // /|\| XIN|-
  11. // | | |
  12. // --|RST XOUT|-
  13. // | P1.6|-->LED
  14. // Button -->|P1.3 P1.0|-->LED
  15. //
  16. // Aldo Briano
  17. // Texas Instruments, Inc
  18. // June 2010
  19. // Built with Code Composer Studio v4
  20. //***************************************************************************************
  21. #include
  22. #define LED_0 BIT0
  23. #define LED_1 BIT6
  24. #define LED_OUT P1OUT
  25. #define LED_DIR P1DIR
  26. #define BUTTON BIT3
  27. unsigned int blink = 0;
  28. void main(void)
  29. {
  30. WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
  31. LED_DIR |= (LED_0 + LED_1); // Set P1.0 and P1.6 to output direction
  32. LED_OUT &= ~(LED_0 + LED_1); // Set the LEDs off
  33. P1IE |= BUTTON;
  34. __enable_interrupt();
  35. for (;;)
  36. {
  37. if(blink > 0)
  38. {
  39. P1OUT ^= (LED_0 + LED_1); // Toggle P1.0 and P1.6 using exclusive-OR
  40. __delay_cycles(100000); // SW Delay of 10000 cycles at 1Mhz
  41. }
  42. }
  43. }
  44. // Port 1 interrupt service routine
  45. #pragma vector=PORT1_VECTOR
  46. __interrupt void Port_1(void)
  47. {
  48. blink ^= 0x01;
  49. P1IFG &= ~BUTTON; // P1.3 IFG cleared
  50. LED_OUT &= ~(LED_0 + LED_1); // Clear the LEDs so they start in OFF state
  51. }
复制代码
发现按按键不起作用,用手指去触碰P1.3或者按键底部的PIN倒有灯闪烁
是按键坏了吗?还是什么情况?
是 P1REN  详情 回复 发表于 2013-9-1 17:49
Msp430奇怪现象 https://bbs.eeworld.com.cn/thread-367244-1-1.html 对于\"Msp430奇怪现象\",问题已解决!!! https://bbs.eeworld.com.cn/thread-367245-1-1.html  详情 回复 发表于 2013-9-1 15:23
2781
419
回复 楼主wgsxsm 的帖子
Msp430奇怪现象
对于"Msp430奇怪现象",问题已解决!!!
谢谢,原来是上下拉电阻的事情不过,我加了那一句就报错是怎么回事呢?  详情 回复 发表于 2013-9-1 17:43
940
原帖由 qinkaiabc 于 2013-9-1 15:23 发表
Msp430奇怪现象
2781
419
回复 板凳wgsxsm 的帖子
P1REN
谢谢,成功了  详情 回复 发表于 2013-9-1 17:53
940
原帖由 qinkaiabc 于 2013-9-1 17:49 发表
是  P1REN
谢谢,成功了
