3199|0
853
Windows Mobile 5.0系统驱动开发环境搭建 [复制链接]
(1)安装Windows Mobile 5.0系统及Platform Builder for Windows Mobile 5.0
WM50_OAK_RTM \Microsoft Platform Builder for Windows Mobile 5.0.msi
(with it can download & debug binary)
(2)安装升级包,升级到WM 6.0
AKU604.msi(Windows Mobile 6 Adaptation Kit Update (AKU) 0.4.10)
(Include BSP&DRV and so on)
(3) 拷贝特定平台相关的资源(BSP、DRV)等
Unzip BSP_WM6_1_PXA310_Handheld_V10_2_2_2_003.zip
copy the content of “platform” folder to “%WM604%platform” folder
platform下的common文件夹,特定平台的那个文件夹(如:Littleton_mhlv),这两个很重要
(4)用向导创建构建脚本
开始-》所有程序-》Microsoft Platform Builder for Windows Mobile 5.0-》New Build Window Wizard
Select your AKU604 installed directory as your OS build tree (比如:I:\WM604)
Select BSP (比如:Littleton_MHLV)and so on.
It will show three new shortcut icon on the PC desktop.
(源文件所在目录WM604 \BuildScripts)
(5)用脚本进行镜像及系统构建(耗时很长)
Select “Build All” to build entire image.
在release目录下会生成大量文件I:\WM604\release\WPC_ Littleton_mhlv _Retail\WPC
(6)烧录到设备上
运行Platform Builder for Windows Mobile 5.0
File->open-> wm604\release\**\WPC\diskimage.nb0
Target-> Connectivity Options 进行连接设置,
Copy \release\******\WPC\Eboot.nb0 to
\Platform Builder for Windows Mobile\5.00\CORECON\BIN\SMDK
Download the run-time image to the target device
Platform builder ->tools – attach device
本文来自赛微电子网,转载请注明出处: http://www.srvee.com/html/66/n-466.html
个人签名如果对linux,Android,wince 等嵌入式底层有兴趣的,请加这个QQ群吧,群号:27100460
