3973|1
854
How to init IIS and IIC to make wm8960 chip play wav file [复制链接]
pin -> signalsAudio_Xi2sSCLK0 [13]Audio_Xi2sCDCLK0 [13]Audio_Xi2sLRCK0 [13]Audio_Xi2sSDO0_0 [1]Audio_Xi2sSDI0 [1]Xi2s0SCLK  GPI[0] Xi2s0CDCLK  GPI[1] Xi2s0LRCK  GPI[2] Xi2s0SDI  GPI[3] Xi2s0SDO[0]  GPI[4] Xi2s0SDO[1]  GPI[5] Xi2s0SDO[2]  GPI[6] GPICON  0xE020_0220 GPIDAT  0xE020_0224 GPIPUD  0xE020_0228 GPIDRV  0xE020_022C SFR of GPIO and IISGPIOPort Group GPI Control Register (GPICON, R/W, Address = 0xE020_0220) GPICON  Bit  Description  Initial State GPICON[6]   [27:24]   0010 = I2S_0_SDO[2]  0010  GPICON[5]   [23:20]   0010 = I2S_0_SDO[1]  0010  GPICON[4]   [19:16]   0010 = I2S_0_SDO[0]              0011 = PCM_0_SOUT   0010  GPICON[3]   [15:12]   0010 = I2S_0_SDI             0011 = PCM_0_SIN    0010  GPICON[2]   [11:8]   0010 = I2S_0_LRCK             0011 = PCM_0_FSYNC  0010  GPICON[1]   [7:4]   0010 = I2S_0_CDCLK             0011 = PCM_0_EXTCLK     0010  GPICON[0]   [3:0]   0010 = I2S_0_SCLK             0011 = PCM_0_SCLK   0010  IISRegister  Address IISCON  0xEEE3_0000 IISMOD  0xEEE3_0004 IISFIC  0xEEE3_0008 IISPSR  0xEEE3_000C IISTXD  0xEEE3_0010 IISRXD  0xEEE3_0014 IISFICS  0xEEE3_0018 IISTXDS  0xEEE3_001C IIC SignalsXi2cSCL0Xi2cSDA0XI2C0SDA XI2C0SCL Xi2c0SDA  GPD1[0]  I2C0_SDA Xi2c0SCL  GPD1[1]  I2C0_SCL GPD1CON[1]   [7:4]       0000 = Input         0001 = Output     0010 = I2C0_SCL     0011 ~ 1110 = Reserved     1111 = GPD1_INT[1]     0000  GPD1CON[0]   [3:0]       0000 = Input         0001 = Output     0010 = I2C0_SDA     0011 ~ 1110 = Reserved     1111 = GPD1_INT[0]     0000  uboot 启动后,IIS 寄存器的配置值:[FriendlyLEG-TINY210]# md 0xeee30000eee30000: 00000000 00000000 00000000 00000000    ................eee30010: 00000000 此处死机Linux 启动后,IIS 寄存器的配置值:[root@FriendlyARM /tmp]# ./sfr 0xeee30000 256addr = 0xeee30000, size = 256 SFR addr = 0xeee30000, size = 0x100eee30000 : 8050cc91      100       40        0 eee30010 :        0        0        0        0 eee30020 :        0        0 7fff0000        0 eee30030 :        0        0        0        0 Linux 上运行 QTopia 视频播放程序 之后再次查看 IIS 配置值:[   54.517075] ASoC_mini210: SCLK=67738000 PSR=6 RCLK=11289600 RFS=256 BFS=32[root@FriendlyARM /]# ./sfr 0xeee30000 64addr = 0xeee30000, size = 64SFR addr = 0xeee30000, size = 0x40eee30000 : 8050c185      600     3f40     8500eee30010 :        0        0        0        0eee30020 :        0        0 7fff0000        0结论: 播放 44.1Khz wav 时,BFS = 32fs, RFS = 256fs, RCLK = 44.1*256 = 11289600, PSR = 6 (5+1), SCLK = 67.738Mhz此时查看 EPLL 配置,发现 0xa8430303 -> EPLL = 67Mhz ,说明 Linux 使用 EPLL 作为 IIS 的输入时钟[root@FriendlyARM /]# ./sfr 0xe0100000 100   e0100100 : a07d0301        0 a29b0c01        0e0100110 : a8430303     bcee        0        0e0100120 : a06c0603        0        0        0e0100130 :        0        0        0        0e0100140 :        0        0        0        0e0100150 :        0        0        0        0e0100160 :        0        0        0        0e0100170 :        0        0        0        0e0100180 :        0        0        0        0begin to write vmem+4总结 IIS 时钟产生过程// IIS clock init    // step 1: EPLL output 67.7Mhz (see p361 of s5pv210.pdf)    // EPLL_CON0/ EPLL_CON1, R/W, Address = 0xE010_0110/0xE010_0114)    // FOUT = (MDIV+K/65536) X FIN / (PDIV X 2SDIV)    // Fout = (0x43+0.7)*24M / (3*2^3) = 80*24M/24 = 67.7Mhz#define EPLL_CON0   (*(volatile unsigned int *)0xe0100110)#define EPLL_CON1   (*(volatile unsigned int *)0xe0100114)    EPLL_CON0 = 0xa8430303;     // MPLL_FOUT = 67.7Mhz    EPLL_CON1 = 0xbcee;     // from linux kernel setting    // step 2: MUX_EPLL = 1 -> SCLK_EPLL = 67.7Mhz (see p361 of s5pv210.pdf)    // CLK_SRC0, R/W, Address = 0xE010_0200    // 0xe0100200: 10001111    // EPLL_SEL  [8]  Control MUXEPLL (0:FINPLL, 1:FOUTEPLL) #define CLK_SRC0    (*(volatile unsigned int *)0xE0100200)          CLK_SRC0 = 0x10001111;    // step 3: Mux_I2S  AUDIO subsystem clock selection (see P1868 P1875 of s5pv210.pdf)#define CLK_CON     (*(volatile unsigned int *)0xEEE10000)      CLK_CON = 0x1;      // 1 = FOUT_EPLL        MUXI2S_A 00 = Main CLK      // IIS SFRs         // step 4:  Divider of IIS (67.7 -> 11.289Mhz)    // N + 1 = (67.7Mhz) / (256 * 44.1Khz) = 5.99    // IISCDCLK  11.289Mhz = 44.1K * 256fs     // IISSCLK    1.4112Mhz = 44.1K * 32fs    // IISLRCLK   44.1Khz    N = 5;    IISPSR = 1<<15 | N<<8;下一步解决 IIC 和 WM8960 驱动/* IIC bus - SCL & SDA 2 signals -> GPD1_0 & GDP1_1 -> GPD0CON */void IIC_init(void){    // set GPIO pin function as IICSCL, IICSDA    GPD1CON |= 0x22;                //GPD1CON[1]  0010 = I2C0_SCL  , GPD1CON[0]  0010 = I2C0_SDA     GPD1PUD |= 0x5;              //Pull-down enable    // Enable ACK, Prescaler IICCLK=PCLK/16, Enable interrupt, Transmit clock value Tx clock=IICCLK/16    IICCON  = (1<<7) | (0<<6) | (1<<5) | (0xf);     // Enable IIC bus    //IICADD  = 0x10;                    // no use if s5pv210 is a IIC master    IICSTAT = 0x10;                    //IIC bus data output enable(Rx/Tx)}   IIC master 工作模式下写 WM8960 的接口 IIC_write/* slave_addr -> WM8960 device addr; addr -> WM8960 reg addr, data -> value */void IIC_write(int slave_addr, int addr, int data){    IICDS = slave_addr;    IICSTAT = 0xf0;    while ((IICCON & 0x10) == 0);   // INT    while ((IICSTAT & 0x1));    // ACK    // 7 bit addr & 9 bit data    IICDS = addr<<1 | ((data>>8) & 0x0001);    IICCON = 0xaf;    while ((IICCON & 0x10) == 0);   // INT    while ((IICSTAT & 0x1));    // ACK    IICDS = (data & 0x00FF);    IICCON = 0xaf;    while ((IICCON & 0x10) == 0);   // INT    while ((IICSTAT & 0x1));    // ACK    IICSTAT = 0xd0; // stop write    IICCON = 0xaf;    return;}WM8960 初始化配置/* 0x34 is WM8960 IIC slave address */void WM8960_init(void){#define WM8960_DEVICE_ADDR      0x34    // reset    IIC_write(WM8960_DEVICE_ADDR, 0xf, 0x0);    // power1 2 3    IIC_write(WM8960_DEVICE_ADDR, 0x19, 1<<8 | 1<<7 | 1<<6);    IIC_write(WM8960_DEVICE_ADDR, 0x1a, 1<<8 | 1<<7 | 1<<6 | 1<<5 | 1<<4 | 1<<3);    IIC_write(WM8960_DEVICE_ADDR, 0x2F, 1<<3 | 1<<2);    // clock    IIC_write(WM8960_DEVICE_ADDR, 0x4, 0x0);        // CLKSEL = 0 : no PLL -> SYSCLK using MCLK     // no mute  ok    IIC_write(WM8960_DEVICE_ADDR, 0x5, 0x0);            // set no mute    //IIC_write(WM8960_DEVICE_ADDR, 0x5, 0x08);     // set mute     // audio interface    IIC_write(WM8960_DEVICE_ADDR, 0x7, 0x2);            // 00 = 16bits,  10 = IIS format    // volume +6db  ok    IIC_write(WM8960_DEVICE_ADDR, 0x2, 0xFF | 0x100);           // WM8960_LOUT1    IIC_write(WM8960_DEVICE_ADDR, 0x3, 0xFF | 0x100);           // WM8960_ROUT1    IIC_write(WM8960_DEVICE_ADDR, 0xa, 0xFF | 0x100);       // Left DAC volume    IIC_write(WM8960_DEVICE_ADDR, 0xb, 0xFF | 0x100);       // Right DAC volume    // mixer control    IIC_write(WM8960_DEVICE_ADDR, 0x22, 1<<8 | 1<<7);       // Left output mixer control    IIC_write(WM8960_DEVICE_ADDR, 0x25, 1<<8 | 1<<7);       // Right output mixer control    return;}
此帖出自Linux开发论坛
个人签名如果对linux,Android,wince 等嵌入式底层有兴趣的,请加这个QQ群吧,群号:27100460
854
链接已隐藏,如需查看请登录或者注册
此帖出自Linux开发论坛
