2980|0
5310
453
HALCoGen 03.06.00下SCI中的bug? [复制链接]
软件环境 :HALCoGen 03.06.00
硬件环境 :TMDX570LS20SUSB
功能开启sci1,sci2
在sciInit函数中
void sciInit(void)
/* USER CODE BEGIN (2) */
/* USER CODE END */
    /** @b initialize @b SCI1 */
    /** - bring SCI1 out of reset */
    sciREG1->GCR0 = 1U;
    /** - Disable all interrupts */
    sciREG1->CLRINT    = 0xFFFFFFFFU;
    sciREG1->CLRINTLVL = 0xFFFFFFFFU;
    /** - global control 1 */
    sciREG1->GCR1 = (1U << 25U)  /* enable transmit */
                  | (1U << 24U)  /* enable receive */
                  | (1U << 5U)   /* internal clock (device has no clock pin) */
                  | ((2U-1U) << 4U)  /* number of stop bits */
                  | (0U << 3U)  /* even parity, otherwise odd */
                  | (0U << 2U)  /* enable parity */
                  | (1U << 1U);  /* asynchronous timing mode */
    /** - set baudrate */
    sciREG1->BRS = 650U;  /* baudrate */
    /** - transmission length */
    sciREG1->FORMAT = 8U - 1U;  /* length */
    /** - set SCI1 pins functional mode */
    sciREG1->FUN = (1U << 2U)  /* tx pin */
                 | (1U << 1U)  /* rx pin */
                 | (0U);  /* clk pin */
    /** - set SCI1 pins default output value */
    sciREG1->DOUT = (0U << 2U)  /* tx pin */
                  | (0U << 1U)  /* rx pin */
    /** - set SCI1 pins output direction */
    sciREG1->DIR = (0U << 2U)  /* tx pin */
    /** - set SCI1 pins open drain enable */
    sciREG1->ODR = (0U << 2U)  /* tx pin */
    /** - set SCI1 pins pullup/pulldown enable */
    sciREG1->PD = (0U << 2U)  /* tx pin */
    /** - set SCI1 pins pullup/pulldown select */
    sciREG1->PSL = (1U << 2U)  /* tx pin */
                 | (1U);  /* clk pin */
    /** - set interrupt level */
    sciREG1->SETINTLVL = (0U << 26U)  /* Framing error */
                       | (0U << 25U)  /* Overrun error */
                       | (0U << 24U)  /* Parity error */
                       | (0U << 9U)  /* Receive */
                       | (0U << 8U)  /* Transmit */
                       | (0U << 1U)  /* Wakeup */
                       | (0U);  /* Break detect */
    /** - set interrupt enable */
    sciREG1->SETINT = (0U << 26U)  /* Framing error */
                    | (1U << 9U)  /* Receive */
    /** - initialize global transfer variables */
    g_sciTransfer_t[0U].mode   = 0U << 8U;
    g_sciTransfer_t[0U].length = 0U;
    /** - Finaly start SCI1 */
    sciREG1->GCR1 |= (1U << 7U);
    /** @b initialize @b SCI2 */
    /** - bring SCI2 out of reset */
    sciREG2->GCR0 = 1U;
    sciREG2->CLRINT    = 0xFFFFFFFFU;
    sciREG2->CLRINTLVL = 0xFFFFFFFFU;
    sciREG2->GCR1 = (1U << 25U)  /* enable transmit */
    sciREG2->BRS = 650U;  /* baudrate */
    sciREG2->FORMAT = 8U - 1U;  /* length */
    /** - set SCI2 pins functional mode */
    sciREG2->FUN = (1U << 2U)  /* tx pin */
    /** - set SCI2 pins default output value */
    sciREG2->DOUT = (0U << 2U)  /* tx pin */
    /** - set SCI2 pins output direction */
    sciREG2->DIR = (0U << 2U)  /* tx pin */
    /** - set SCI2 pins open drain enable */
    sciREG2->ODR = (0U << 2U)  /* tx pin */
    /** - set SCI2 pins pullup/pulldown enable */
    sciREG2->PD = (0U << 2U)  /* tx pin */
    /** - set SCI2 pins pullup/pulldown select */
    sciREG2->PSL = (1U << 2U)  /* tx pin */
    sciREG2->SETINTLVL = (0U << 26U)  /* Framing error */
    sciREG2->SETINT = (0U << 26U)  /* Framing error */
这里自动生成为"0U",应该是"1U"
    /** - Finaly start SCI2 */
    sciREG2->GCR1 |= (1U << 7U);
/* USER CODE BEGIN (3) */
/* USER CODE END */
