9523|10
怎么感觉msp430g2553例程中的关于SPI的那个程序有问题,求大神指点 [复制链接]
初学SPI,调用了例程中的SPI 程序,发现中断中UCA0RXBUF的值一直都是0xff, 灯亮只发生在SLV_Data也等于0xff时,为什么???
求大神指点
附源程序:
//   MSP430G2xx3 Demo - USCI_A0, SPI 3-Wire Master Incremented Data
//   Description: SPI master talks to SPI slave using 3-wire mode. Incrementing
//   data is sent by the master starting at 0x01. Received data is expected to
//   be same as the previous transmission.  USCI RX ISR is used to handle
//   communication with the CPU, normally in LPM0. If high, P1.0 indicates
//   valid data reception.
//   ACLK = n/a, MCLK = SMCLK = DCO ~1.2MHz, BRCLK = SMCLK/2
//   Use with SPI Slave Data Echo code example. If slave is in debug mode, P3.6
//   slave reset signal conflicts with slave's JTAG; to work around, use IAR's
//   "Release JTAG on Go" on slave device.  If breakpoints are set in
//   slave RX ISR, master must stopped also to avoid overrunning slave
//   RXBUF.
//                    MSP430G2xx3
//             /|\|              XIN|-
//              --|RST          XOUT|-
//                |             P1.2|-> Data Out (UCA0SIMO)
//          LED <-|P1.0         P1.1|<- Data In (UCA0SOMI)
//  Slave reset <-|P1.5         P1.4|-> Serial Clock Out (UCA0CLK)
//   D. Dang
//   Texas Instruments Inc.
//   February 2011
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include "msp430g2553.h"
unsigned char MST_Data, SLV_Data;
void main(void)
  volatile unsigned int i;
  WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog timer
  P1OUT = 0x00;                             // P1 setup for LED & reset output
  P1DIR |= BIT0 + BIT5;                     //
  P1SEL = BIT1 + BIT2 + BIT4;              //BIT1 :SPIMISO,BIT2 :SPIMOSI,BIT4:UCA0CLK
  P1SEL2 = BIT1 + BIT2 + BIT4;
  UCA0CTL0 |= UCCKPL + UCMSB + UCMST + UCSYNC;  // 3-pin, 8-bit SPI master
  UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  UCA0BR0 |= 0x02;                          // /2
  UCA0BR1 = 0;                              //
  UCA0MCTL = 0;                             // No modulation
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI0 RX interrupt
  P1OUT &= ~BIT5;                           // Now with SPI signals initialized,
  P1OUT |= BIT5;                            // reset slave
  __delay_cycles(75);                 // Wait for slave to initialize
  MST_Data = 0x01;                          // Initialize data values
  SLV_Data = 0x00;
  UCA0TXBUF = MST_Data;                     // Transmit first character
  __bis_SR_register(LPM0_bits + GIE);       // CPU off, enable interrupts
// Test for valid RX and TX character
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCIA0RX_ISR(void)
  while (!(IFG2 & UCA0TXIFG));              // USCI_A0 TX buffer ready?
  if (UCA0RXBUF == SLV_Data)                // Test for correct character RX'd
    P1OUT |= BIT0;                          // If correct, light LED
  else
    P1OUT &= ~BIT0;                         // If incorrect, clear LED
  MST_Data++;                               // Increment master value
  SLV_Data++;                               // Increment expected slave value
  UCA0TXBUF = MST_Data;                     // Send next value
  __delay_cycles(50);                     // Add time between transmissions to
}                                           // make sure slave can keep up
我用的5529的spi主从机的例程啊,无全速运行程序也没有看到p1.0的灯亮啊,这是怎么回事啊??球解答啊,怎么样验证这个例程实现的数据传输的啊???各位大神帮帮忙啊  详情 回复 发表于 2017-3-2 16:06
你的官方程序从哪里搞的?发一份给我,邮箱945445295@qq.com  详情 回复 发表于 2013-10-24 20:04
推荐
回复 沙发qwqwqw2088 的帖子
是官方例程,试了好几遍都有问题,不知道是程序有问题,还是我的操作有问题??
程序直接运行的时候能看到G2553的P1.0对应的红灯微弱的亮,感觉程序可能对了,然后就单步执行,发现中断中UCA0RXBUF的值一直都是0xff, 灯亮只发生在SLV_Data也等于0xff时,如果这样的话,貌似与原程序目的不一样啊
这样的串行通信是不能用单步调试来看正确与否的,我也是用的官方的例程,完全没有问题,LED就是用来判断收发数据的正确与否的,首先串行通信就不应该在没有传输完成的时候中断,这样就会导致传输出错,你还是全速运  详情 回复 发表于 2013-8-15 23:48
342
这引用的是官方例程?
是官方例程,试了好几遍都有问题,不知道是程序有问题,还是我的操作有问题?? 程序直接运行的时候能看到G2553的P1.0对应的红灯微弱的亮,感觉程序可能对了,然后就单步执行,发现中断中UCA0RXBUF的值一直都是0xf  详情 回复 发表于 2013-8-5 22:41
1976
回复 板凳dreamchaser09 的帖子
这样的串行通信是不能用单步调试来看正确与否的,我也是用的官方的例程,完全没有问题,LED就是用来判断收发数据的正确与否的,首先串行通信就不应该在没有传输完成的时候中断,这样就会导致传输出错,你还是全速运行看指示灯或者选择更为合适的断点吧
赞赏
查看全部赞赏
91
这个是因为你没有把P1.1和P1.2短接,你短接就可以看到P1.0的灯亮了
39
回复 楼主dreamchaser09 的帖子
请问这个程序的问题解决了吗?我现在也正在做SPI通信,望指点!
我也觉得有问题啊,一开始发送的是1,怎么与0相等红灯亮啊
   else
     P1OUT &= ~BIT0;
按这个程序,SLV-DATA始终比返回的值小一啊
99
也不知这坟帖的问题是否解决了,今天也在此郁闷了很久,终于找到原因了,确实是一直出不了中断,应用的时候得特别注意。在SPI发出数据时也会触发接受中断!!!!!!!!!!!就是这个原因;
41
