4683|2
695
配置MSP430F6的频率失败了. [复制链接]
经常在运行过程中有这个错误.
MSP430: Trouble Reading Memory Block at 0x23fc on Page 0 of Length 0x2: Could not determine device state  如果发生,在程序第一句就会发生
MSP430: Failed Software Reset: Could not read Enhanced Emulation Module register 在PMM设置后发生
MSP430: Trouble Reading Memory Block at 0x23fc on Page 0 of Length 0x2: No error 不设置PMM的话,直接配置时候会发生
MSP430: Trouble Reading Memory Block at 0xf3ffe on Page 0 of Length 0x95: Invalid parameter(s) 不设置PMM,直接设置也可能发生
配置外部32.768khz rtc时钟,必复位MCU.
TARGET:MSP430F6721
  1. #include
  2. /*
  3. * main.c
  4. */
  5. int main(void) {
  6.         WDTCTL = WDTPW | WDTHOLD;        // Stop watchdog timer
  7.
  8.     PJDIR |= BIT0 | BIT1 | BIT3;
  9.     PJSEL |= BIT0 | BIT1 | BIT3;
  10. //
  11. //    PMMCTL0_H = PMMPW_H;
  12. //    SVSMHCTL = SVSHE + SVSHRVL0 * PMMCOREV_3 + SVMHE + SVSMHRRL0 * PMMCOREV_3;
  13. //    SVSMLCTL = SVSLE + SVMLE + SVSMLRRL0 * PMMCOREV_3;
  14. //    while ((PMMIFG & SVSMLDLYIFG) == 0);
  15. //    PMMIFG &= ~(SVMLVLRIFG + SVMLIFG);
  16. //    PMMCTL0_L = PMMCOREV0 * PMMCOREV_3;
  17. //    if ((PMMIFG & SVMLIFG))
  18. //      while ((PMMIFG & SVMLVLRIFG) == 0);
  19. //    SVSMLCTL = SVSLE + SVSLRVL0 * PMMCOREV_3 + SVMLE + SVSMLRRL0 * PMMCOREV_3;
  20. //    PMMCTL0_H = 0x00;
  21.     // DCO  = 31 MOD = 0
  22.     UCSCTL0_H = 31;
  23.     UCSCTL1_L = DCORSEL_7;
  24.     UCSCTL4 = SELA__VLOCLK | SELS__DCOCLK | SELM__DCOCLK;
  25.     UCSCTL5 = DIVA__32 | DIVS__8 | DIVM__1;
  26.     UCSCTL6 &= ~(XT1OFF);
  27.     UCSCTL6 |= XCAP_3;
  28. //
  29. //    do
  30. //    {
  31. //        UCSCTL7 &= ~(XT2OFFG | XT1LFOFFG | DCOFFG);
  32. //        SFRIFG1 &= ~OFIFG;
  33. //    } while (SFRIFG1 & OFIFG);
  34.     _nop();
  35.     while(1){
  36.     }
  37. }
复制代码
怎么处理
同上所求啊 !  楼上最后怎么解决的啊???紧急求助!!!  详情 回复 发表于 2014-10-14 09:19
你好  我目前用的是MSP430F6731   XT1怎么配置也震荡不起来  您的问题现在解决了吗
