2022|4
求助 pwm驱动led灯 按键可以步进 朋友们 谢谢了 [复制链接]
谢谢了
#include   #define CPU_F ((double)1000000) #define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0)) #define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0)) #define PWM_P 0xFFFF #define PWM_2 0xFFF #define PWM_3 0xEFF #define KEY1 BIT3 void SET0(void);//Standby void SET30(void);//30% Dim void SET100(void);//No Dim void SET_FL(void);//Flash Mode unsigned char STU1=0; void main(void) {       WDTCTL = WDTPW + WDTHOLD;// Stop watchdog timer to prevent time out reset   DCOCTL|= MOD0+DCO0;//  +DCO1+DCO2           //Set DCO Frequence select   BCSCTL1|=DIVA_0+RSEL0;// +RSEL1+RSEL2+RSEL3    // Set DCO Resistor      P1DIR &= ~BIT3;                          //P1.3 input   P1REN |=BIT3;                            // P1.3 pullup   P1IE |= BIT3;                            // P1.3 interrupt enabled   P1IES |= BIT3;                           // P1.3 Hi/lo edge   P1IFG &= ~BIT3;                          // P1.3 IFG cleared      STU1=0;   SET0();         _BIS_SR(LPM3_bits + GIE);                       // Enter LPM3 } #pragma vector=PORT1_VECTOR __interrupt void Port_1 (void) {   if((P1IFG&KEY1)==KEY1) //KEY1 按下   {    delay_ms(20);     if((P1IN&KEY1)==0)     {       switch(STU1)       {       case 0:           SET100();           STU1=1;           break;       case 1:           SET30();                STU1=2;           break;       case 2:           SET_FL();           STU1=3;           break;      case 3:           STU1=0;           SET0();           break;       }       P1IFG &= ~BIT3;                           // P1.3 IFG cleared     }    }   } void SET100(void) {   P1DIR |= BIT6+BIT4+BIT0;// P1.2 and P1.3 output   P1SEL |=BIT4+BIT0;//   P1OUT |=BIT6+BIT4+BIT0;// } void SET30(void) {   P1DIR |= BIT6+BIT4+BIT0;//                            // P1.2 and P1.3 output   P1SEL |= BIT6+BIT4+BIT0;//                            // P1.2 and P1.3 TA1/2 options   P1OUT |= BIT3;      CCR0 = PWM_P;                             // PWM Period   CCTL1 = OUTMOD_3;                         // CCR1 reset/set   CCR1 = PWM_3;                               // CCR1 PWM duty cycle   TACTL = TASSEL_2 + MC_1;                  // MCLK, up mode } void SET0(void) {   P1OUT  &= BIT6;   P1IFG &= ~BIT3; //_BIS_SR(LPM4_bits + GIE);   } void SET_FL(void)                   //Flash Mode {   P1DIR |= BIT6;                            // P1.2 and P1.3 output   P1SEL |= BIT6;                            // P1.2 and P1.3 TA1/2 options   P1OUT |= BIT6;      CCR0 = PWM_P;                             // PWM Period   CCTL1 = OUTMOD_2;                         // CCR1 reset/set   CCR1 = PWM_3;                               // CCR1 PWM duty cycle   TACTL = TASSEL_1 + MC_1;                  // ACLK, up mode }  详情 回复 发表于 2013-7-15 11:14
楼主可以先写程序,遇到问题请大家帮忙  详情 回复 发表于 2013-7-9 10:30
管理员
回复 楼主侯成斌1988126 的帖子
楼主可以先写程序,遇到问题请大家帮忙
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
嗯 谢谢你  详情 回复 发表于 2013-7-9 12:04
加油!在电子行业默默贡献自己的力量!:)
回复 沙发soso 的帖子
嗯   谢谢你
119
这样简单的问题,还要大家帮助?
#include
#define PWM_2 0xFFF
#define PWM_3 0xEFF
#define KEY1 BIT3
void main(void)
  STU1=0;
  SET0();
   delay_ms(20);
    if((P1IN&KEY1)==0)
      switch(STU1)
      case 0:
          SET100();
          STU1=1;
          break;
      case 1:
          SET30();
          STU1=2;
          break;
      case 2:
          SET_FL();
          STU1=3;
          break;
     case 3:
          STU1=0;
          SET0();
          break;
void SET100(void)
void SET30(void)
  P1OUT |= BIT3;
void SET0(void)
  P1OUT  &= BIT6;
  P1IFG &= ~BIT3;
  P1OUT |= BIT6;
