2343|1
695
SMCLK为什么提前起振了? [复制链接]
如果单独一个USCI使用则不会,现在我配置两个完全一样的USCI_A模块.
相同配置,只在最后一个USCI启用中断
但是SMCLK在SPI第四个时候后就..启动了/
#include
void InitHC_A(){
        P1SEL |= BIT2 | BIT3 | BIT6;
        UCA0CTLW0 |= UCSWRST;
        UCA0CTLW0 |= UCMST | UCSYNC | UCCKPL | UCMSB;
        UCA0CTLW0 |= UCSSEL_1;
        UCA0MCTLW = 0;
        UCA0CTLW0 &= ~UCSWRST;
        //UCA0IE = UCTXIE;
        UCA0IE = 0x00;
void InitHC_B(){
        P2SEL |= BIT4;
        P1SEL |= BIT4 | BIT5;
        UCA1CTLW0 |= UCSWRST;
        UCA1CTLW0 |= UCMST | UCSYNC | UCCKPL | UCMSB;
        UCA1CTLW0 |= UCSSEL_1;
        UCA1MCTLW = 0;
        UCA1CTLW0 &= ~UCSWRST;
        UCA1IE = UCTXIE;
int main(void) {
    WDTCTL = WDTPW | WDTHOLD;        // 关闭看门狗
    PJDIR |= BIT3 | BIT0;
    PJSEL |= BIT3 | BIT0;
    InitHC_A();
    InitHC_B();
        while(1){
                P4DIR |= BIT0 | BIT1;
                P4OUT |= BIT0 | BIT1;
                UCA0TXBUF = 0xAA;
                UCA1TXBUF = 0x55;
                _bis_SR_register(LPM3_bits + GIE);
                P4OUT &= ~(BIT0 | BIT1);
                P4DIR &= ~(BIT0 | BIT1);
#pragma vector=USCI_A1_VECTOR
__interrupt void USCI_A1_ISR(void)
    switch (__even_in_range(UCA1IV, 4))
        case USCI_NONE: break;                    // No interrupt
        case USCI_SPI_UCRXIFG:break;                  // RXIFG
        case USCI_SPI_UCTXIFG: break;             // TXIFG
        default: break;
    _bic_SR_register_on_exit(LPM3_bits + GIE);
  详情 回复 发表于 2013-7-9 06:55
4996
裸片初长成(初级)
个人签名我的博客
