2418|2
299
3831
msp430f149键盘输入数字小程序 [复制链接]
看到大家大多帖子是g2553的,我用的是mspf149,就共享下我刚刚编的小程序。可能和g2553端口功能不同:整个程序的功能是:s2开关选择某一位(我一共设置了4位,所以输入数值为0000-9999之间);s1开关为选择的位0-9循环自加;
s3为确定键,将输入的数值放入d[]数组;s4为取消暂时没加入功能;
------------------下面是main。c-------------------------------------------------------------------------
#include
#define uchar unsigned char
void LcdReset(void);
void Disp1Char(unsigned char x,unsigned char y,unsigned char data);
void DispStr(uchar x,uchar y,uchar *ptr);
#define keyin    (P1IN & 0x0f)
void delay(void);
void main()
  WDTCTL = WDTPW + WDTHOLD;
  P1DIR = 0xf0;
  unsigned char temp;
  LcdReset();
  uchar s[]={0,0,0,0};      //中间变化数组
  uchar d[]={0,0,0,0};      //最后确定输出数组
  for(int m=4;m>0;m--)
    uchar i=0;
    uchar j=0;
    Disp1Char(j,0,0x30+s);j++;i++;
   uchar j=0;
   uchar i=0;
   DispStr(0,1,\"OK\");
   DispStr(8,1,\"CANCER\");
  while(1)
        if(keyin != 0x0f)       //键值有改变
            delay();            //延时消抖
            if(keyin != 0x0f)   //再次检测按键状态
                temp=keyin;
                while(keyin != 0x0f);   //等待按键被放开
                switch(temp)    //转换键值
                case 0x0e:
                        i++;
                        i%=10;
                        Disp1Char(j,0,0x30+i);
                       s[j]=i;
                        break;
                case 0x0d:
                         j++;
                         if(j==4)
                         j=0;
                         break;
                case 0x0b:
                         for(int m=0;m<4;m++)
                           d[m]=s[m];
                         DispStr(6,0,\"d=\");
                          uchar n=12;
                               Disp1Char(n,0,0x30+d[m]);n++;
void delay(void)
    unsigned int tmp;
    for(tmp = 12000;tmp > 0;tmp--);
------------------下面是1602LCD的控制程序 ---------------------
#include
void DispStr(unsigned char x,unsigned char y,unsigned char *ptr);
void DispNChar(unsigned char x,unsigned char y, unsigned char n,unsigned char *ptr);
void LocateXY(unsigned char x,unsigned char y);
void LcdWriteCommand(unsigned char cmd,unsigned char chk);
void LcdWriteData( unsigned char data );
void WaitForEnable(void);
void Delay5ms(void);
typedef unsigned int  uint;
/**************宏定义***************/
#define DataDir     P4DIR
#define DataPort    P4OUT
#define Busy            0x80
#define CtrlDir     P3DIR
#define CLR_RS P3OUT&=~BIT0;    //RS = P3.0
#define SET_RS P3OUT|=BIT0;
#define CLR_RW P3OUT&=~BIT1;        //RW = P3.1
#define SET_RW P3OUT|=BIT1;
#define CLR_EN P3OUT&=~BIT2;        //EN = P3.2
#define SET_EN P3OUT|=BIT2;
函数名称:DispStr
功    能:让液晶从某个位置起连续显示一个字符串
参    数:x--位置的列坐标
          y--位置的行坐标
          ptr--指向字符串存放位置的指针
返回值  :无
    uchar *temp;
    uchar i,n = 0;
    temp = ptr;
    while(*ptr++ != '\0')   n++;    //计算字符串有效字符的个数
    for (i=0;i     {
        Disp1Char(x++,y,temp);
        if (x == 0x0f)
           x  = 0;
           y ^= 1;
函数名称:DispNchar
功    能:让液晶从某个位置起连续显示N个字符
参    数:x--位置的列坐标
          y--位置的行坐标
          n--字符个数
          ptr--指向字符存放位置的指针
返回值  :无
void DispNChar(uchar x,uchar y, uchar n,uchar *ptr)
    uchar i;
    for (i=0;i     {
        Disp1Char(x++,y,ptr);
        if (x == 0x0f)
           x = 0;
        y ^= 1;
函数名称:LocateXY
功    能:向液晶输入显示字符位置的坐标信息
参    数:x--位置的列坐标
          y--位置的行坐标
返回值  :无
void LocateXY(uchar x,uchar y)
    uchar temp;
    temp = x&0x0f;
    y &= 0x01;
    if(y)   temp |= 0x40;  //如果在第2行
    temp |= 0x80;
    LcdWriteCommand(temp,1);
函数名称:Disp1Char
功    能:在某个位置显示一个字符
参    数:x--位置的列坐标
          y--位置的行坐标
          data--显示的字符数据
返回值  :无
void Disp1Char(uchar x,uchar y,uchar data)
    LocateXY( x, y );
    LcdWriteData( data );
函数名称:LcdReset
功    能:对1602液晶模块进行复位操作
参    数:无
返回值  :无
void LcdReset(void)
    CtrlDir |= 0x07;                 //控制线端口设为输出状态
    DataDir  = 0xFF;                 //数据端口设为输出状态
    LcdWriteCommand(0x38, 0);            //规定的复位操作
    Delay5ms();
    Delay5ms();
    Delay5ms();
    LcdWriteCommand(0x38, 1);                //显示模式设置
    LcdWriteCommand(0x08, 1);                //显示关闭
    LcdWriteCommand(0x01, 1);            //显示清屏
    LcdWriteCommand(0x06, 1);                //写字符时整体不移动
    LcdWriteCommand(0x0c, 1);                //显示开,不开游标,不闪烁
函数名称:LcdWriteCommand
功    能:向液晶模块写入命令
参    数:cmd--命令,
          chk--是否判忙的标志,1:判忙,0:不判
返回值  :无
void LcdWriteCommand(uchar cmd,uchar chk)
    if (chk) WaitForEnable();   // 检测忙信号?
    CLR_RS;
    CLR_RW;
    _NOP();
    DataPort = cmd;             //将命令字写入数据端口
    _NOP();
    SET_EN;                     //产生使能脉冲信号
    _NOP();
    _NOP();
    CLR_EN;
函数名称:LcdWriteData
功    能:向液晶显示的当前地址写入显示数据
参    数:data--显示字符数据
返回值  :无
void LcdWriteData( uchar data )
    WaitForEnable();        //等待液晶不忙
    SET_RS;
    CLR_RW;
    _NOP();
    DataPort = data;        //将显示数据写入数据端口
    _NOP();
    SET_EN;                 //产生使能脉冲信号
    _NOP();
    _NOP();
    CLR_EN;
函数名称:WaitForEnable
功    能:等待1602液晶完成内部操作
参    数:无
返回值  :无
    P4DIR &= 0x00;  //将P4口切换为输入状态
    CLR_RS;
    SET_RW;
    _NOP();
    SET_EN;
    _NOP();
    _NOP();
    while((P4IN & Busy)!=0);  //检测忙标志
    CLR_EN;
    P4DIR |= 0xFF;  //将P4口切换为输出状态
函数名称:Delay5ms
功    能:延时约5ms
参    数:无
返回值  :无
void Delay5ms(void)
    uint i=40000;
    while (i != 0)
        i--;
效果图:
赞一个,支持亲手实践  详情 回复 发表于 2013-6-28 23:10
672
支持楼主,
话说你149的板子好性感
5015
裸片初长成(初级)
赞一个,支持亲手实践
个人签名《MCU工程师炼成记》作者之一
