2770|4
28
裸片初长成(高级)
教你如何看器件手册的DC参数 [复制链接]
1 前言 .................................................................................................................. 2
2 VOS (Input Offset Voltage) .................................................................................................. 2
3 TCVOS (Input Offset Voltage Drift) ......................................................................................... 3
4 IIN (Input Current) ............................................................................................................ 4
5 IOS (Input Offset Current) ................................................................................................... 4
6 TCIOS (Input Offset Current Drift) .......................................................................................... 4
7 IB (Bias Current) ............................................................................................................. 5
8 CMRR (Common Mode Rejection Ratio) ................................................................................ 6
9 PSRR (Power Supply Rejection Ratio) .................................................................................. 7
10 AVOL (Open Loop/Large Signal Voltage Gain) ........................................................................... 8
11 VO (Voltage Swing) .......................................................................................................... 8
12 IO (Output Short Circuit Current) .......................................................................................... 9
13 IS (Supply Current) .......................................................................................................... 9
14 CMVR (Common Mode Voltage Range) ................................................................................. 9
教你如何看器件的DC参数.pdf (91.66 KB, 下载次数: 89)
给力,谢谢楼主分享!        学习了!   详情 回复 发表于 2013-8-2 09:25
顶起。。。  详情 回复 发表于 2013-6-14 00:53
9203
管理员
  好资料,收藏了
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
33
回复 楼主 dontium 的帖子
顶起。。。
414
给力,谢谢楼主分享!
学习了!
【直播时间】5月28日(周三)上午10:00
