19101|1
343
Altium Designer新版一个关于栅格(Grid)的设置方法 [复制链接]
Altium Designer新版一个关于栅格(Grid)的设置方法,对需要极坐标布LED圆板的朋友是重大利好!
Nesting and Grid Priority
Grids you define in the Grid Manager dialog can be freely stacked within the board area. By specifying origin coordinates accordingly, you can overlap grids, creating a nested hierarchy of grids, with which to fine tune placement of design objects as you layout your board.
Grid contention – which grid in an overlapping stackup of grids should a design object snap to – is resolved using a priority system. Each local placement grid you create and define is given a numbered priority. By default, each new grid is given the highest priority of 1, with all existing grids moved down in priority accordingly.
The Global Board Snap Grid is an exception. As it is the default grid that is used in all areas of the board that are not 'covered' by defined custom grids, it is given the priority setting of Default. It has the lowest 'snapping priority' of all defined grids.
In the workspace, priority is distinguished by drawing order. The highest priority grid (priority 1) will be drawn in front of all other grids, then the grid with priority level 2, and so on, down to the default Global Board Snap Grid, which is drawn behind all other custom grids.
从这个视频中可以看出,AltiumDesigner的最新版是可以多个栅格型式并存的——极坐标和直角坐标在同一个界面并存,多个栅格尺寸在同一个界面并存。
此帖出自PCB设计论坛
咦,这个动画搞的不错啊,怎么做到的呢!  详情 回复 发表于 2013-6-6 19:11
点赞 关注(1)
1149
咦,这个动画搞的不错啊,怎么做到的呢!
此帖出自PCB设计论坛
Vicor 有奖下载 | 在48V架构中使用高密度功率转换器构建更好的机器人
活动时间:即日起-4月28日
活动奖励:螺丝刀套装、充电套装、电风扇
