2958|0
51
写入flash的数据和读出的不一致,为什么啊? [复制链接]
今天尝试 读写flash,改自TI官方代码,我准备了一个变量,可写入进去的和读出的不一致,请大家帮我看看。
void write_SegC (unsigned int *array)
  unsigned char *Flash_ptr;                          // Flash pointer
  Flash_ptr = (unsigned char *) 0x1040;              // Initialize Flash pointer
  FCTL1 = FWKEY + ERASE;                    // Set Erase bit
  FCTL3 = FWKEY;                            // Clear Lock bit
  *Flash_ptr = 0;                           // Dummy write to erase Flash segment
  FCTL1 = FWKEY + WRT;                      // Set WRT bit for write operation
    *Flash_ptr++ = *array;                   // Write value to flash  }
  FCTL1 = FWKEY;                            // Clear WRT bit
  FCTL3 = FWKEY + LOCK;                     // Set LOCK bit
void read (void)
  unsigned char *Flash_ptrC;                         // Segment C pointer
  unsigned char *Flash_ptrD;                         // Segment D pointer
  Flash_ptrC = (unsigned char *) 0x1040;             // Initialize Flash segment C pointer
  Flash_ptrD = (unsigned char *) 0x1000;             // Initialize Flash segment D pointer
  *Flash_ptrD = 0;                          // Dummy write to erase Flash segment D
    *value = *Flash_ptrC++;          // copy value segment C to segment D
  Nor_Val = value[0];
//时钟初始化
void  Clk_Init(void)
  if (CALBC1_8MHZ==0xFF)     // If calibration constant erased
    while(1);                               // do not load, trap CPU!!
  DCOCTL = 0;                               // Select lowest DCOx and MODx settings
  BCSCTL1 = CALBC1_8MHZ;                    // Set range
  DCOCTL = CALDCO_8MHZ;                     // Set DCO step + modulation */
  BCSCTL2 |=  SELM_1  + DIVM_3;
  FCTL2 = FWKEY + FSSEL0 + FN1;             // MCLK/3 for Flash Timing Generator
  //BCSCTL3 |= XT2S0 + LFXT1S0 + XCAP_3;      //配置ACLK匹配电容
