5698|0
beaglebone nfs 无法挂载 求助解答 [复制链接]
PC上虚拟机里的linux10.04已经装好beaglebone的SDK;
portmap_6.0-r3.1_armv7a.ipk  已经在beaglebone上安装成功
nfs-utils-client_1.1.2-2.1_armv7a.ipk 安装时,有如下显示:
Installing nfs-utils (1.2.3-r3) to root...
nfs-utils: unsatisfied recommendation for kernel-module-nfsd  //请问这个是什么意思???
Configuring nfs-utils.
System startup links for /etc/init.d/nfsserver already exist.
启动nfs服务,
首先启动portmap成功;
启动nfsserver,如下
root@beaglebone:~# /etc/init.d/nfsserver start
creating NFS state directory: done
starting 8 nfsd kernel threads: rpc.nfsd: Unable to access /proc/fs/nfsd errno 2 (No such file or directory).  //没弄明白
Please try, as root, 'mount -t nfsd nfsd /proc/fs/nfsd' and then restart rpc.nfsd to correct the problem
done //没弄明白
starting mountd: done
starting statd: done
现在开始把PC 的共享目录挂在到beaglebone上,如下
root@beaglebone:~# mount 192.168.80.128:/mnt  /mnt         //主机的IP地址是192.168.80.128,主机NFS 配置也已经开启
mount: wrong fs type, bad option, bad superblock on 192.168.80.128:/mnt,
       missing codepage or helper program, or other error
       (for several filesystems (e.g. nfs, cifs) you might
       need a /sbin/mount. helper program)
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
而且beaglebone对自己的文件进行挂载时也显示如上报错,哪位大侠帮我解答一下??非常感谢!
