Sat Jun 01, 2013 19:05:48: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 6.4\arm\config\flashloader\AnalogDevices\FlashADUCM3xx.mac
Sat Jun 01, 2013 19:05:48: JLINK command: ProjectFile = E:\PRJ\ADI\My360\settings\My360_Debug.jlink, return = 0
Sat Jun 01, 2013 19:05:48: DLL version: V4.40
Sat Jun 01, 2013 19:05:48: Firmware: J-Link ARM V8 compiled Jul 6 2012 18:56:24
Sat Jun 01, 2013 19:05:48: Selecting SWD as current target interface.
Sat Jun 01, 2013 19:05:48: JTAG speed is initially set to: 32 kHz
Sat Jun 01, 2013 19:05:48: Found SWD-DP with ID 0x2BA01477
Sat Jun 01, 2013 19:05:49: FPUnit: 6 code (BP) slots and 2 literal slots
Sat Jun 01, 2013 19:05:49: Found Cortex-M3 r2p0, Little endian.
Sat Jun 01, 2013 19:05:49: SYSRESETREQ has confused core. Trying to reconnect and use VECTRESET.
Sat Jun 01, 2013 19:05:49: Found SWD-DP with ID 0x2BA01477
Sat Jun 01, 2013 19:05:49: Core did not halt after reset, trying to disable WDT.
Sat Jun 01, 2013 19:05:51: Found SWD-DP with ID 0x2BA01477
Sat Jun 01, 2013 19:05:52: SYSRESETREQ has confused core. Trying to reconnect and use VECTRESET.
Sat Jun 01, 2013 19:05:52: Found SWD-DP with ID 0x2BA01477
Sat Jun 01, 2013 19:05:52: Core did not halt after reset, trying to disable WDT.
Sat Jun 01, 2013 19:06:04: Fatal error: Wrong AHB ID (15:3). Expected 0x04770001 (Mask 0x0FFFFFCF), Found 0x00000000 Session aborted!
Sat Jun 01, 2013 19:06:04: Failed to load flash loader: C:\Program Files\IAR Systems\Embedded Workbench 6.4\arm\config\flashloader\AnalogDevices\FlashADUCM3xx128K_8K.flash
E2E上找到这个:
It is most likely a connectivity issue on your board. Use a multi-meter to check continuity between the MCU and the JTAG pins. Make sure TDI and TDO are properly connected not swapped. We generally recommend pull-ups on several of the JTAG lines.
Is the oscillator for the 2965 running? What is the LDO voltage? Have you connected VDDA and GNDA?
We have recently published a system design guideline application note that details how to connect and do a good hardware design with our parts. It is located at http://www.ti.com/lit/an/spma036/spma036.pdf. Make sure you have followed those guidelines.
by Stellaris Dexter on Feb 10 2012 14:50 PM
Genius13845 points
IAR 6.0 should work fine with the 2965 but you may want to try upgrading as well to their latest version, I believe it is at least 6.3
