3611|0
853
测试内存稳定性代码分享 [复制链接]
這種東西當然是要加在C:\WINCE600\PLATFORM\SMDKV210\SRC\BOOTLOADER\STEPLDR\main.c裡面
不然是要怎嚜測試整各DRAM
void main(void)
Port_Init();
Led_Display_Off(1); //RED
Led_Display_Off(2); //BLUE
Led_Display_On(3);  //GREEN
if(!DRAM_Test())
    Led_Display_On(1); //RED
    RAM_Error();
BOOL DRAM_Test(void);
unsigned long* DRAM_DeviceTest(unsigned long *BaseAddr, unsigned long nBytes);
unsigned long* DRAM_AddrBusTest(unsigned long *BaseAddr, unsigned long nBytes);
unsigned long  DRAM_DataBusTest(unsigned long *Addr);
//* \fn    DRAM_DataBusTest
//* \brief Test the DRAM Data Bus
//* return succeed return 0 / fail return Data Value
unsigned long pattern;
for(pattern = 1; pattern != 0; pattern <<= 1)
*Addr = pattern;
Addr[1] = ~pattern;
if(*Addr != pattern)
return pattern;
return 0;
//* \fn    DRAM_AddrBusTest
//* \brief Test the DRAM Address Bus
//* return succeed return 0 / Fail return Error Address
//* 測試區塊盡可能為2的次方
unsigned long offset,testOffset;
unsigned long pattern = 0xAAAAAAAA;
unsigned long antipattern = 0x55555555;
unsigned long addressMask = (nBytes - 1)>>2; /*設定用來當成停止狀況,一次測試4個Bytes*/
for(offset = 4;(offset & addressMask) != 0; offset <<= 1)
BaseAddr[offset] = pattern;
/*檢查是否有其他位址線也出現1的訊號*/
BaseAddr[0] = antipattern;
if(BaseAddr[offset] != pattern)
return (unsigned long*) &BaseAddr[offset];
BaseAddr[0] = pattern;
/*檢查是否有短路或誤接到低電位的位址線*/
for(testOffset = 4;(testOffset & addressMask) != 0; testOffset <<= 1)
BaseAddr[testOffset] = antipattern;
if(BaseAddr[offset] != pattern && (offset != testOffset))
return (unsigned long*) &BaseAddr[testOffset];
BaseAddr[testOffset] = pattern;
return 0;
//* \fn    DRAM_DeviceTest
unsigned long offset;
unsigned long nDWords = nBytes/4;
unsigned long pattern=0xAAAAAAAA;
unsigned long antipattern=0x55555555;
//將整個記憶體填入已知的資料數值
for(offset = 0;offset < nDWords; offset++)
if(offset % 0x100000 == 0)
DebugString(".");
//確認每個位址上的資料,並將他反向,作第二回合測試
for(offset = 0;offset < nDWords;offset++)
return (unsigned long*)&BaseAddr[offset];
BaseAddr[offset] = antipattern;
DebugString(".");
//確認每個位址上的資料是否被反向,然後歸0
for(pattern = 1,offset = 0;offset < nDWords; pattern++,offset++)
if(BaseAddr[offset] != antipattern)
BaseAddr[offset] = 0;
DebugString(".");
DebugString("\n");
    //確認Data Bus ok
    if(BaseAddr[0] != pattern)
return (unsigned long*)&BaseAddr[0];
    if(BaseAddr[0] != antipattern)
//確認Address Bus ok
for(offset = 0;offset < nDWords;) //offset++
    offset++;
if(BaseAddr[offset] != antipattern || BaseAddr[offset-1] != pattern)
    offset++;
return 0;
//* \fn    DRAM_Test
//* \brief Test All the DRAM: Data/Address/Every Bit
unsigned long Value;
unsigned long *pValue;
unsigned long DRAM0_BASE = 0x20000000;
unsigned long DRAM0_SIZE =  0x8000000; //128M
unsigned long DRAM1_BASE = 0x40000000;
unsigned long DRAM1_SIZE =  0x8000000; //128M
Value = DRAM_DataBusTest((unsigned long *)DRAM1_BASE);
if(Value != 0)
//DebugString("DRAM1 Data Bus Error\n");
return FALSE;
pValue = DRAM_AddrBusTest((unsigned long *)DRAM1_BASE,DRAM1_SIZE);
if(pValue != 0)
//DebugString("DRAM1 Address Bus Error\n");
return FALSE;
pValue = DRAM_DeviceTest((unsigned long *)DRAM1_BASE,DRAM1_SIZE);
if(pValue != 0)
//DebugString("DRAM1 Device Error\n");
return FALSE;
Value = DRAM_DataBusTest((unsigned long *)DRAM0_BASE);
if(Value != 0)
//DebugString("DRAM0 Data Bus Error\n");
return FALSE;
pValue = DRAM_AddrBusTest((unsigned long *)DRAM0_BASE,DRAM0_SIZE);
if(pValue != 0)
//DebugString("DRAM0 Address Bus Error\n");
return FALSE;
pValue = DRAM_DeviceTest((unsigned long *)DRAM0_BASE,DRAM0_SIZE);
if(pValue != 0)
//DebugString("DRAM0 Device Error\n");
return FALSE;
  return TRUE;
个人签名如果对linux,Android,wince 等嵌入式底层有兴趣的,请加这个QQ群吧,群号:27100460
【有奖直播】2025是德科技数字月-数字新品来助阵
直播时间:3月19日(周三)14:00
直播奖励:小米口红充电宝、倍思充电线、是德科技十周年鼠标垫
