21
楼主,74HC573应该与哪些IO口连接呀,是不是74HC573的输入端与P1口连接,输出端与D1~D9连接
180
22
楼主求帮忙。。。。我发一段代码,也是430的,就是跑不起来/**************控制端定义**************/
/*********选用P4口送DH,P3口送DL********/
/******P9.0控制CS端,P9.1控制RS端******/
/******P9.2控制RW端,P9.3控制RD端******/
/*************P9.4控制RES端************/
#define TFT_CS_1 P9OUT|=BIT0   //片选端
#define TFT_CS_0 P9OUT&=~BIT0
#define TFT_RS_1 P9OUT|=BIT2   //数据命令选择端
#define TFT_RS_0 P9OUT&=~BIT2
#define TFT_WR_1 P9OUT|=BIT1   //写
#define TFT_WR_0 P9OUT&=~BIT1
#define TFT_RD_1 P9OUT|=BIT3   //读
#define TFT_RD_0 P9OUT&=~BIT3
#define TFT_RES_1 P9OUT|=BIT4  //复位
#define TFT_RES_0 P9OUT&=~BIT4
void LCD_WR_DATA(uint Data)
  uchar DH,DL;
  DH=Data>>8;
  DL=Data;
  TFT_CS_0;
  //delayms(1);
  TFT_RS_1;
  //delayms(1);
  P4OUT=DH;
  P3OUT=DL;
  TFT_WR_0;
  //delayms(1);
  TFT_WR_1;
  //delayms(1);
  TFT_CS_1;
  //delayms(1);
/***********LCD写寄存器*****************/
void LCD_WR_REG(uint Index)
  uchar DH,DL;
  DH=Index>>8;
  DL=Index;
  TFT_CS_0;
  //delayms(1);
  TFT_RS_0;
  //delayms(1);
  P4OUT=DH;
  P3OUT=DL;
  TFT_WR_0;
  //delayms(1);
  TFT_WR_1;
  //delayms(1);
  TFT_CS_1;
  //delayms(1);
/********在指定寄存器写数据************/
void LCD_WriteReg(uint Index,uint Data)
  LCD_WR_REG(Index);
  LCD_WR_DATA(Data);
/**********初始化驱动芯片**************/
void ILI9481_Initial()
  LCD_WR_REG(0x11);
  delayms(20);
  LCD_WR_REG(0xD0);
  LCD_WR_DATA(0x07);
  LCD_WR_DATA(0x42);
  LCD_WR_DATA(0x18);
  LCD_WR_REG(0xD1);
  LCD_WR_DATA(0x00);
  LCD_WR_DATA(0x07);
  LCD_WR_DATA(0x10);
  LCD_WR_REG(0xD2);
  LCD_WR_DATA(0x01);
  LCD_WR_DATA(0x02);
  LCD_WR_REG(0xC0);
  LCD_WR_DATA(0x10);
  LCD_WR_DATA(0x3B);
  LCD_WR_DATA(0x00);
  LCD_WR_DATA(0x02);
  LCD_WR_DATA(0x11);
  LCD_WR_REG(0xC5);
  LCD_WR_DATA(0x03);
  LCD_WR_REG(0xC8);
  LCD_WR_DATA(0x00);
  LCD_WR_DATA(0x32);
  LCD_WR_DATA(0x36);
  LCD_WR_DATA(0x45);
  LCD_WR_DATA(0x06);
  LCD_WR_DATA(0x16);
  LCD_WR_DATA(0x37);
  LCD_WR_DATA(0x75);
  LCD_WR_DATA(0x77);
  LCD_WR_DATA(0x54);
  LCD_WR_DATA(0x0C);
  LCD_WR_DATA(0x00);
  LCD_WR_REG(0x36);
  LCD_WR_DATA(0x0A);
  LCD_WR_REG(0x3A);
  LCD_WR_DATA(0x55);
  LCD_WR_REG(0x2A);
  LCD_WR_DATA(0x00);
  LCD_WR_DATA(0x00);
  LCD_WR_DATA(0x01);
  LCD_WR_DATA(0x3F);
  LCD_WR_REG(0x2B);
  LCD_WR_DATA(0x00);
  LCD_WR_DATA(0x00);
  LCD_WR_DATA(0x01);
  LCD_WR_DATA(0xE0);
  delayms(120);
  LCD_WR_REG(0x29);
  LCD_WR_REG(0x2c);
/*************初始化函数****************/
void init_TFT()
  TFT_CS_1;
  delayms(50);
  TFT_RES_0;
  delayms(150);
  TFT_RES_1;
  delayms(50);
  ILI9481_Initial();
void main()
  init_430();
  init_TFT();
  P8DIR=0xff;
  while(1)
    ClearScreen(BLACK);
    P8OUT=0xff;
    delayms(1000);
    P8OUT=0x00;
    delayms(1000);
P8.1接了一个led,实测led正常闪烁但是液晶只有背光亮,求解决办法
23
楼主真给力啊!!!!!!!!
24
9325的用不了啊!!!!!!!!!!!!!!怎么设置十六位传输呢 我这么貌似没有锁存器啊
26
楼主好人
