lowlevel_init.S的system_clock_init函数放到C语言下面实现——更好处理
在uboot原来的代码里,有系统时钟的初始化函数,在board/samsung/smdkv210/lowlevel_init.S的system_clock_init函数,我大概看了一下,寄存器不一样,而且是汇编写的,所以我就改成用c语言来实现,在BL1阶段初始化一下,BL2阶段就不用重新初始化了。 1.arch/arm/lib/spl.c +43添加 [cpp] view plaincopy
- //SystemClock
- #define APLL_LOCK (*(volatile unsigned int *)0xE0100000)
- #define MPLL_LOCK (*(volatile unsigned int *)0xE0100008)
- #define EPLL_LOCK (*(volatile unsigned int *)0xE0100010)
- #define VPLL_LOCK (*(volatile unsigned int *)0xE0100020)
- #define APLL_CON0 (*(volatile unsigned int *)0xE0100100)
- #define APLL_CON1 (*(volatile unsigned int *)0xE0100104)
- #define MPLL_CON (*(volatile unsigned int *)0xE0100108)
- #define EPLL_CON0 (*(volatile unsigned int *)0xE0100110)
- #define EPLL_CON1 (*(volatile unsigned int *)0xE0100114)
- #define VPLL_CON (*(volatile unsigned int *)0xE0100120)
- #define CLK_SRC0 (*(volatile unsigned int *)0xE0100200)
- #define CLK_DIV0 (*(volatile unsigned int *)0xE0100300)
- #define SETPLL(mdiv, pdiv, sdiv) ((1<<31)|(mdiv<<16)|(pdiv<<8)|(sdiv<<0))
- #define APLL_MDIV 250
- #define APLL_PDIV 6
- #define APLL_SDIV 1
- #define APLL_CON0_VAL SETPLL (APLL_MDIV, APLL_PDIV, APLL_SDIV)
- #define MPLL_MDIV 667
- #define MPLL_PDIV 12
- #define MPLL_SDIV 1
- #define MPLL_CON_VAL SETPLL (MPLL_MDIV, MPLL_PDIV, MPLL_SDIV)
- #define PCLK_PSYS_RATIO 1
- #define HCLK_PSYS_RATIO 4
- #define PCLK_DSYS_RATIO 1
- #define HCLK_DSYS_RATIO 3
- #define PCLK_MSYS_RATIO 1
- #define HCLK_MSYS_RATIO 4
- #define A2M_RATIO 4
- #define APLL_RATIO 0
- #define CLK_DIV0_VAL ( (APLL_RATIO<<0)|\
- (A2M_RATIO<<4)|\
- (HCLK_MSYS_RATIO<<8)|\
- (PCLK_MSYS_RATIO<<12)|\
- (HCLK_DSYS_RATIO<<16)|\
- (PCLK_DSYS_RATIO<<20)|\
- (HCLK_PSYS_RATIO<<24)|\
- (PCLK_PSYS_RATIO<<28) )
2. arch/arm/lib/spl.c +135添加[cpp] view plaincopy
- void init_SystemClock (void)
- int i;
- //CLK_DIV0 = 0;
- APLL_CON0 = APLL_CON0_VAL;
- MPLL_CON = MPLL_CON_VAL;
- CLK_SRC0 = 0x1111;
- CLK_DIV0 = CLK_DIV0_VAL;
- //for (i=65535; i>=0; i--);
3. include/configs/smdkv210.h +178[cpp] view plaincopy
- /*#define CONFIG_SYS_PROMPT "SMDKC100 # "*/
- #define CONFIG_SYS_PROMPT "SMDKV210 # "
4. include/configs/smdkv210.h +206 [cpp] view plaincopy
- /*#define CONFIG_IDENT_STRING " for SMDKC100"*/
- #define CONFIG_IDENT_STRING " for SMDKV210"
5. arch/arm/lib/spl.c +183 [cpp] view plaincopy
- void __weak board_init_f(ulong dummy)
- __attribute__((noreturn)) void (*uboot)(void);
- #if 0
- /* Set the stack pointer. */
- asm volatile("mov sp, %0\n" : : "r"(CONFIG_SPL_STACK));
- /* Clear the BSS. */
- memset(__bss_start, 0, __bss_end__ - __bss_start);
- /* Set global data pointer. */
- gd = &gdata;
- board_init_r(NULL, 0);
- #endif
- // test
- #define GPH0CON (*(volatile unsigned int *)0xE0200C00)
- #define GPH0DAT (*(volatile unsigned int *)0xE0200C04)
- GPH0CON = (1<<0) | (1<<4) | (1<<8) | (1<<12);
- GPH0DAT = 10;
- init_SystemClock();
- uart_init();
- copy_uboot_to_ram();
- //printf ("jump to u-boot image\r\n");
- /* Jump to U-Boot image */
- uboot = (void *)CONFIG_SYS_TEXT_BASE;
- (*uboot)();
6. 好了,make一下,使用命令烧写spl/smdkv210-spl.bin和u-boot.bin到SD卡里,启动,就会看到下面这个画面了。
原文地址 http://blog.chinaunix.net/uid-25445243-id-3552427.html
