* @file SPI/CRC/main.c
* @author MCD Application Team
* @version V3.5.0
* @date 08-April-2011
* @brief Main program body
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* @param None
* @retval None
int main(void)
/*!< At this stage the microcontroller clock setting is already configured,
this is done through SystemInit() function which is called from startup
file (startup_stm32f10x_xx.s) before to branch to application main.
To reconfigure the default setting of SystemInit() function, refer to
system_stm32f10x.c file
/* System clocks configuration ---------------------------------------------*/
RCC_Configuration();
/* Transfer procedure */
while (TxIdx < BufferSize - 1)
/* Wait for SPI1 Tx buffer empty */
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
/* Send SPI2 data */
SPI_I2S_SendData(SPI2, SPI2_Buffer_Tx[TxIdx]);
/* Send SPI1 data */
SPI_I2S_SendData(SPI1, SPI1_Buffer_Tx[TxIdx++]);
/* Wait for SPI2 data reception */
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET);
/* Read SPI2 received data */
SPI2_Buffer_Rx[RxIdx] = SPI_I2S_ReceiveData(SPI2);
/* Wait for SPI1 data reception */
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
/* Read SPI1 received data */
SPI1_Buffer_Rx[RxIdx++] = SPI_I2S_ReceiveData(SPI1);
/* Wait for SPI2 Tx buffer empty */
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
/* Send last SPI2_Buffer_Tx data */
/* Enable SPI2 CRC transmission */
SPI_TransmitCRC(SPI2);
/* Send last SPI1_Buffer_Tx data */
SPI_I2S_SendData(SPI1, SPI1_Buffer_Tx[TxIdx]);
/* Enable SPI1 CRC transmission */
SPI_TransmitCRC(SPI1);
/* Wait for SPI1 last data reception */
/* Read SPI1 last received data */
SPI1_Buffer_Rx[RxIdx] = SPI_I2S_ReceiveData(SPI1);
/* Wait for SPI2 last data reception */
/* Read SPI2 last received data */
/* Wait for SPI1 data reception: CRC transmitted by SPI2 */
/* Wait for SPI2 data reception: CRC transmitted by SPI1 */
/* Check the received data with the send ones */
TransferStatus1 = Buffercmp(SPI2_Buffer_Rx, SPI1_Buffer_Tx, BufferSize);
TransferStatus2 = Buffercmp(SPI1_Buffer_Rx, SPI2_Buffer_Tx, BufferSize);
/* TransferStatus1, TransferStatus2 = PASSED, if the data transmitted and received
are correct */
/* TransferStatus1, TransferStatus2 = FAILED, if the data transmitted and received
are different */
/* Test on the SPI1 CRC Error flag */
if ((SPI_I2S_GetFlagStatus(SPI1, SPI_FLAG_CRCERR)) == SET)
TransferStatus2 = FAILED;
/* Test on the SPI2 CRC Error flag */
if ((SPI_I2S_GetFlagStatus(SPI2, SPI_FLAG_CRCERR)) == SET)
TransferStatus1 = FAILED;
/* Read SPI1 received CRC value */
CRC1Value = SPI_I2S_ReceiveData(SPI1);
/* Read SPI2 received CRC value */
CRC2Value = SPI_I2S_ReceiveData(SPI2);
while (1)
* @brief Configures the different system clocks.
* @param None
* @retval None
void RCC_Configuration(void)
/* PCLK2 = HCLK/2 */
RCC_PCLK2Config(RCC_HCLK_Div2);
* @brief Configures the different GPIO ports.
* @param None
* @retval None
void GPIO_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure;
/* Configure SPI1 pins: SCK, MISO and MOSI ---------------------------------*/
/* Confugure SCK and MOSI pins as Alternate Function Push Pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Confugure MISO pin as Input Floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/* Configure SPI2 pins: SCK, MISO and MOSI ---------------------------------*/
/* Confugure SCK and MOSI pins as Input Floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* Confugure MISO pin as Alternate Function Push Pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
* @brief Compares two buffers.
* @param pBuffer1, pBuffer2: buffers to be compared.
* @param BufferLength: buffer's length
* @retval PASSED: pBuffer1 identical to pBuffer2
* FAILED: pBuffer1 differs from pBuffer2
TestStatus Buffercmp(uint16_t* pBuffer1, uint16_t* pBuffer2, uint16_t BufferLength)
while (BufferLength--)
if (*pBuffer1 != *pBuffer2)
return FAILED;
pBuffer1++;
pBuffer2++;
return PASSED;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
