12996|6
59
ccs5.2连接XDS100V2 连不上 [复制链接]
请教一下大家,我使用XDS100V2对CCS5.2,但是现在死活连接不上,请大家帮忙分析一下问题出在哪里。
首先是驱动已经安装好了,如图:
然后建立CCXML配置文件,选择XDS100V2和TMS320F28030芯片后,点击test connection后,提示出现fail,如下:
[Start]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\YuAnNing\AppData\Local\.TI\1212777678\
0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioserdesusb.dll'.
The library build date was 'May 30 2012'.
The library build time was '22:52:27'.
The library package version is '5.0.747.0'.
The library component version is '35.34.40.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '4' (0x00000004).
The controller has an insertion length of '0' (0x00000000).
This utility will attempt to reset the controller.
This utility has successfully reset the controller.
-----[Print the reset-command hardware log-file]-----------------------------
The scan-path will be reset by toggling the JTAG TRST signal.
The controller is the FTDI FT2232 with USB interface.
The link from controller to target is direct (without cable).
The software is configured for FTDI FT2232 features.
The controller cannot monitor the value on the EMU[0] pin.
The controller cannot monitor the value on the EMU[1] pin.
The controller cannot control the timing on output pins.
The controller cannot control the timing on input pins.
The scan-path link-delay has been set to exactly '0' (0x0000).
-----[The log-file for the JTAG TCLK output generated from the PLL]----------
There is no hardware for programming the JTAG TCLK frequency.
-----[Measure the source and frequency of the final JTAG TCLKR input]--------
There is no hardware for measuring the JTAG TCLK frequency.
-----[Perform the standard path-length test on the JTAG IR and DR]-----------
This path-length test uses blocks of 512 32-bit words.
The test for the JTAG IR instruction path-length succeeded.
The JTAG IR instruction path-length is 38 bits.
The test for the JTAG DR bypass path-length succeeded.
The JTAG DR bypass path-length is 1 bits.
-----[Perform the Integrity scan-test on the JTAG IR]------------------------
This test will use blocks of 512 32-bit words.
This test will be applied just once.
Do a test using 0xFFFFFFFF.
Scan tests: 1, skipped: 0, failed: 0
Do a test using 0x00000000.
Scan tests: 2, skipped: 0, failed: 0
Do a test using 0xFE03E0E2.
Test 3 Word 6: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 7: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 8: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 9: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 10: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 11: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 12: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 13: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
The details of the first 8 errors have been provided.
The utility will now report only the count of failed tests.
Scan tests: 3, skipped: 0, failed: 1
Do a test using 0x01FC1F1D.
Scan tests: 4, skipped: 0, failed: 2
Do a test using 0x5533CCAA.
Scan tests: 5, skipped: 0, failed: 3
Do a test using 0xAACC3355.
Scan tests: 6, skipped: 0, failed: 4
Some of the values were corrupted - 66.3 percent.
The JTAG IR Integrity scan-test has failed.
-----[Perform the Integrity scan-test on the JTAG DR]------------------------
Test 3 Word 17: scanned out 0xFE03E0E2 and scanned in 0xFFFFE0E2.
Test 3 Word 18: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 19: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 20: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 21: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 22: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 23: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Test 3 Word 24: scanned out 0xFE03E0E2 and scanned in 0xFFFFFFFF.
Some of the values were corrupted - 65.9 percent.
The JTAG DR Integrity scan-test has failed.
[End]
如果点击此时点击debug的话,会报错,如图:
(借个图,我的实际提示是:The emulator reported an error .Confirm emulator configuration ande connections,
reset the emulator.  and retry the  operation.
程序是软件自带的,仿真器是同事正常用的。
现在我就是不太清楚到底是驱动出现了问题,还是调试器的硬件出现问题,哪位有经验的可以指点一下。谢谢。
[ 本帖最后由 sw0605 于 2013-4-25 09:22 编辑 ]
哦,谢谢,没注意那一楼  详情 回复 发表于 2013-4-27 09:52
2856
260
图片显示驱动不对
2856
260
图片显示驱动不对
59
ccs5.3连接XDS100V2 没问题了
捣鼓出来了,我的是芯片的问题,见网上也有这样的问题,就是不知道他们的是什么原因了。
不过连上是用的5.3,就是ccs5.3连接XDS100V2可以的。不知道5.2怎么样了。
呵呵!
121
同求这个问题,不知道楼主解决没有啊,希望讨论下啊
我不是写的很清楚了么? 我现在安装的是5.3的连接没有问题  详情 回复 发表于 2013-4-27 08:07
59
回复 5楼 放开那个鸡腿 的帖子
我不是写的很清楚了么?
我现在安装的是5.3的连接没有问题
121
回复 6楼 sw0605 的帖子
哦,谢谢,没注意那一楼
