2184|0
诡异的串口无法发送 [复制链接]
写的熔丝位匹配程序,可以进入if判断语句,就是不往串口寄存器UDR0写入数据0x55,求高人解答,感激涕零!
#include
#include
#define F_CPU 12000000UL
#define baud 9600
int fuse_check();
void uart0_init(void);
void delay_1ms();
void main()
     uart0_init();
    if(fuse_check()==0)
         while(1)
                           while( !(UCSR0A & (1<
                               UDR0 = 0x55;        //发送数据0x55
                               //delay_1ms();
         //else
            // UDR0 = 0x66;        //发送数据0x66
int fuse_check()
         unsigned int a=0,b=1;
         // 读取熔丝位低字节
         asm("LDI R30,0x00");        //赋0x0000给Z指针
         asm("LDI R31,0x00");
         SPMCSR = 0x09;                         //置位SPMCSR寄存器
         asm("LPM");                 //读取低字节数据给R0
         asm("STS 0x002E,R0");  //复制R0数据给PORTE
         if(PORTE==0x0C)                //低字节匹配判断
                        //读取熔丝位高字节
                         asm("LDI R30,0x03");        //赋0x0003给Z指针
                         SPMCSR=0x09;                         //置位SPMCSR寄存器
                         if(PORTE==0x00)                        //高字节匹配判断
                                        //读取熔丝位扩展字节
                                         asm("LDI R30,0x02");        //赋0x0002给Z指针
                                         if(PORTE==0x4A)                        //扩展字节匹配判断
                                b=0;
                                                return b;
                                        else
                                                a=1;
                                                return a;
                     else
                                 a=1;
                                 return a;
        else
                 a=1;
                 return a;
//UART0初始化
        UCSR0A = 0x00; //设置波特率时无效
    UCSR0B = 0x00;
    UCSR0C = 0x00;
    UBRR0L =(F_CPU/baud/8-1)%256;
    UBRR0H =(F_CPU/baud/8-1)/256;
    UCSR0C = (1<
    UCSR0B = (1<
