2998|5
5014
裸片初长成(初级)
惊闻TIdeals上Chronos手表有20美金的大幅降价 [复制链接]
听说TIdeals上Chronos手表降价20美金,便宜了120多块RMB,可惜我现在就是上不去这个网站,哪位兄弟能够速速观摩一下,打探清楚情况。
网址是这个:http://tideals.com/
Here’s the Deal: Hey look, it’s the Chronos programmable watch! Believe it or not, we receive more requests for this tool than any other by far, so we brought it back. And if you were lucky enough to snag an SA430 Sub-GHz Spectrum Analyzer in the TI Deal we just had, adding a Chronos RF Watch will help you build a sweet RF network! Remember how it works… we’ve got a limited quantity at this price. The deal is good for two weeks or until we sell out, whichever comes first! -------------------------------------------------------------------------------- TI Deal eZ430-Chronos wireless watch $58 $38 -------------------------------------------------------------------------------- What You Get! ■eZ430-Chronos wireless watch ■CC1111 USB RF access point ■CD containing documentation and development software ■eZ430 USB programming and debugging interface ■2 spare screws ■Mini Phillips screwdriver eZ430 Features: ■Fully functional sports watch based on the CC430F6137 ■MSP430 with integrated ■Watch reprogrammable for custom wireless applications ■Highly integrated watch includes: ■on-board 3-axis accelerometer ■pressure sensor ■temperature sensor ■battery voltage sensor ■96-Segment LCD display driven directly by CC430 ■Can be paired wirelessly with heart rate monitors, pedometers or other devices based on RF transceivers like the CC430 or CC1111 ■Includes an eZ430 USB emulator that connects the Chronos to a PC for real-time, in-system programming and debugging ■Includes IAR Kickstart and Code Composer Studio integrated development environments ■Watch is 30m waterproof. See FAQ section in User Guide for details. Want more info? Check out these Product Training Modules on Digi-Key: Microcontrollers: eZ430-Chronos Development Tool Microcontrollers: eZ430 Development Tool Overview Also, you can head over to ti.com to check out a Chronos workshop as well as a wiki dedicated to Chronos projects.  详情 回复 发表于 2013-4-19 21:27
个人签名《MCU工程师炼成记》作者之一
335
可以买的啊。
Quantity
Digi-Key Part Number
Manufacturer Part Number
Digi-Key Stock
Standard Resale Price*
Discount Pricing*
EZ430-CHRONOS-433-DEAL-ND
EZ430-CHRONOS-433
DEV WRLESS WATCH TOOL FOR CC430
467
59.16000
38.00000
EZ430-CHRONOS-868-DEAL-ND
EZ430-CHRONOS-868
2160
59.16000
38.00000
EZ430-CHRONOS-915-DEAL-ND
EZ430-CHRONOS-915
DEV WRLESS WATCH TOOL FOR CC431
2422
59.16000
38.00000
*All prices are in US dollars.
*Applicable taxes will be added to your order at submit time. All duties and taxes are the responsibility of the customer.
335
全部都是38美金。楼主要吗?
全部都是38美金。楼主要吗?
335
上面说卖两周或者卖完为止。
上面说卖两周或者卖完为止。
:Sweat: 虽然降了,还是略贵!  详情 回复 发表于 2013-4-19 21:27
335
Here’s the Deal:
TI Deal
$58
$38
What You Get!
■2 spare screws
eZ430 Features:
■pressure sensor
■temperature sensor
Want more info?
5014
裸片初长成(初级)
回复 4楼 yanxinboy 的帖子
虽然降了,还是略贵!
个人签名《MCU工程师炼成记》作者之一
立即报名 | 2025 瑞萨电子工业以太网技术日即将开启!
预报从速,好礼等您拿~
