2809|2
43
SEED-EXP430F5529 入门之定时器 [复制链接]
收到EE送的SEED-EXP430F5529后,写了个定时器测试程序
定时器测试例程:
//  MSP430F552X  - Timer0_A5, Toggle P1.0,P8.1,P8.2, TA0CCR0 Cont. Mode ISR,ACLK
//  Description: Toggle P1.0 P8.1 P8.2 using software and Timer0_A0 ISR. Toggles every
//  50000 ACLK cycles. ACLK provides clock source for ACLK.
//  During the Timer0_A0 ISR, P1.0 P8.1 P8.2 is toggled and 50000 clock cycles are added to
//  TA0CCR0. Timer0_A0 ISR is triggered every 50000 cycles. CPU is normally off and
//  used only during TA_ISR.
//  ACLK =32.768KHZ , MCLK = SMCLK = default DCO ~2MHz
//              MSP430F552X
//        /|\|              XIN|-
//         --|RST          XOUT|-
//           |             P1.0|-->LED1
//           |             P8.1|-->LED2
//           |             P8.2|-->LED3
//  lingmin
//  Built with  IAR Embedded Workbench Version: 5.30.1
#include "msp430f5529.h"
void main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  P1DIR |=0X01;                               //P1.O output
  P8DIR |=0X06;                              //P8.1,P8.2 output
  TA0CCTL0 = CCIE;                           // TA0CCR0 interrupt enabled
  TA0CCR0 = 50000;
  TA0CTL = TASSEL_1 + MC_2;                  // ACLK, contmode
  _BIS_SR(LPM3_bits+GIE);
// Timer A0 interrupt service routine
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer_A0 (void)
  P1OUT ^= 0x01;                            // Toggle P1.0
  P8OUT ^= 0X06;
  TA0CCR0 += 50000;                          // Add Offset to TA0CCR0
529.08 KB, 下载次数: 6
542.11 KB, 下载次数: 0
534.97 KB, 下载次数: 0
不哦啊哦都撒娇的离开计量监理  详情 回复 发表于 2013-4-3 17:16
不哦啊哦都撒娇的离开计量监理
不哦啊哦都撒娇的离开计量监理
