3104|2
210的tft做硬件把数据线画反了,rgb 做成bgr了 求助内核改哪里能调整 [复制链接]
修改以下函数,但只能修改是引导正确。进入安卓后颜色还是不对,求助大侠给予帮助。叩首再叩首!
static void s3cfb_set_bitfield(struct fb_var_screeninfo *var)
     switch (var->bits_per_pixel) {
     case 16:
         if (var->transp.length == 1) {
             var->red.offset = 10;
             var->red.length = 5;
             var->green.offset = 5;
             var->green.length = 5;
             var->blue.offset = 0;
             var->blue.length = 5;
             var->transp.offset = 15;
         } else if (var->transp.length == 4) {
             var->red.offset = 8;
             var->red.length = 4;
             var->green.offset = 4;
             var->green.length = 4;
             var->blue.length = 4;
             var->transp.offset = 12;
         } else {
             var->red.offset = 11;
             var->green.length = 6;
             var->transp.offset = 0;
         break;
     case 24:
         var->red.offset = 16;
         var->red.length = 8;
         var->green.offset = 8;
         var->green.length = 8;
         var->blue.length = 8;
         var->transp.length = 0;
         break;
     case 32:
         var->transp.offset = 24;
         var->transp.length = 8;
         break;
看看哪条线搞错了,再把数据位作一运算就行了  详情 回复 发表于 2013-2-2 23:04
这个是驱动吧,你把r和b的位替换一下应该就可以了
裸片初长成(高级)
