6890|4
5272
裸片初长成(中级)
这样使用微软的Visual Studio开发msp430你见过么? [复制链接]
要装一个插件,我没怎么找,所以还不知道怎样能有破解方法,所以发出来大家看看,有办法的告诉一声呀
Visual Studio便捷功能强大,应该很方便编程呀,别说大炮打蚊子吆
哎,问个问题难有答案呀,能不能给点力么?
Using Visual Studio to develop MSP430 firmware
In this tutorial we will show you how to develop and debug a simple \"LED blinking\" firmware for TI MSP430 microcontrollers using VisualGDB. We use the EZ430-RF2500 development board to demonstrate the integration with debugging tools; however, you can use any of those tools/programmers supported by the MSP430.DLL provided by TI.
The full list of the MSP430 devices supported by VisualGDB can be found here.
Step-by-step guide
Before you begin, please ensure that you installed the latest version of VisualGDB. Once it's installed, follow the steps below:
  • Start Visual Studio, select \"File->New->Project\". Then select \"Visual C++->VisualGDB\". Please avoid spaces in directory names, as GDB does not support it.
  • In VisualGDB wizard select \"Firmware for an embedded device\" and press \"next\".
  • As you are creating a default new project, you don't have to change anything on next wizard page.
  • Select \"MSP430\" from the toolchain list. If the MSP430 toolchain has not been installed before, VisualGDB will download and install it automatically. You can also download it yourself fromhttp://gnutoolchains.com/msp430.
  • VisualGDB will show the toolchain versions available for download. Please select the latest one.
  • Select the installation directory and press \"Install\" to start toolchain installation.
  • Once the toolchain has been installed, press the \"Next\" button on the toolchain selection page.
  • Select the MCU type that you want to target. The EZ430-RF2500 kit has the msp430f2274 MCU. The LaunchPad board comes with msp430g2553. You can use the \"Filter\" textbox to simplify finding the right MCU.
  • On the next page enter the location of the LED. The EZ430-RF2500 and LaunchPad have a LED connected to P1.0, so the default settings will work.
  • On the debug settings page select \"mspdebug Simulator\". Press Finish when done.
  • Congratulations! You have created a Visual Studio project for a simple MSP430 firmware. Press Ctrl+Shift+B or select Build->Build Solution to build the project.
  • To start debugging, put a breakpoint on the line assigning P1OUT and start the debug session via Debug->Start debugging with GDB command:
  • When the breakpoint is hit you can use the normal Visual Studio techniques to debug your program. Hover the mouse over the P1OUT register. Visual Studio will show the value:
  • The Debug Server window will show the output from mspdebug. If you encounter any problems, refer to it for additional information.
  • You can step through your program, modify variable values, change next statement, just like you are debugging a Windows application. When done, press Shift+F5 to stop debugging.
  • Now we will debug a real device over JTAG. Right-click on the project in Solution Explorer and select \"VisualGDB Project Properties\".
  • Change the debug method to JTAG (gdbproxy++) and accept default settings:
  • You can start debugging your firmware over JTAG by selecting Debug->Start debugging with GDB. The FLASH memory will be programmed automatically.
额滴神啊  详情 回复 发表于 2013-4-8 10:30
个人签名没工作,没女人老婆,没宽带 ,  没钱
2776
413
这么给力
2452
怕是不如专业的好用
28
裸片初长成(高级)
使用Visual Studio ,主要是使用它的编辑功能,因为Visual Studio的编辑功能非常好。
过去我用过VC编译其它的东西时,是使用它能运行别的编译器的功能。
61
额滴神啊
