3190|2
1302读出的时间不走怎么回事啊。。。哪位大哥指教一下啊 [复制链接]
#include
#include
#define uchar unsigned char
#define uint unsigned int
//位选段选
#define we_set PORTA|=BIT(0)//
#define we_clr PORTA&=~BIT(0)//
#define du_set PORTA|=BIT(1)//
#define du_clr PORTA&=~BIT(1)//
//1302端口定义
#define clk_set PORTB|=BIT(0)
#define clk_clr PORTB&=~BIT(0)
#define clk_OUT DDRB|=BIT(0)//
#define io_set PORTB|=BIT(1)//
#define io_clr PORTB&=~BIT(1)//
#define io_OUT DDRB|=BIT(1)//
#define io_IN DDRB&=~BIT(1)//
#define io_r PINB&BIT(1)//
#define rst_set PORTB|=BIT(2)//
#define rst_clr PORTB&=~BIT(2)//
#define rst_OUT DDRB|=BIT(2)//
void write_ds1302_byte(uchar dat);//单字节写
void write_ds1302(uchar add,uchar dat);//多字节写
uchar read_ds1302(uchar add);
uchar const table_we[]={0xDF,0xef,0xf7,0xfb,0xfd,0xfe};
uchar const table_du[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f};
uchar disp[8];
uchar i;
uchar time_date[7]={12,1,11,23,12,02,02};//年周月日时分秒
uchar write_add[7]={0x8c,0x8a,0x88,0x86,0x84,0x82,0x80};//写年月日地址
uchar read_add[7]={0x8d,0x8b,0x89,0x87,0x85,0x83,0x81};//读比写多1
void set_rtc(void);//对时间
void read_rtc(void);//读时间
void time_pros(void);//处理函数
void dispiay(void);        //显示函数
void delay(uint xms)//延时函数
        uint n,m;
        for(n=xms;n>0;n--)
                for(m=124;m>0;m--);
void duanko(void)//端口初始化
         DDRA=0XFF;
         PORTA=0XFF;
         DDRC=0XFF;
         PORTC=0Xff;
void write_ds1302_byte(uchar dat)//单字节写
         io_OUT;
         for(i=0;i<8;i++)
                 clk_clr;
                 if(dat&0x01)
                     io_set;
                 else
                     io_clr;
                 clk_set;
                 clk_clr;
                 dat=dat>>1;
void write_ds1302(uchar add,uchar dat)//写多个字节
        rst_clr;
    clk_clr;
        rst_set;
        write_ds1302_byte(add);//写地址
        write_ds1302_byte(dat);//写数据
        rst_clr;
        //io_set;
        //clk_set;
uchar read_ds1302(uchar add)//读地址
    uchar value;
        rst_clr;
    clk_clr;
        rst_set;
        io_IN;
        for(i=0;i<8;i++)
            value=value>>1;
                 if(io_r)
                     value=value|0x80;
                 clk_set;
                 clk_clr;
        rst_clr;
        return value;
void set_rtc(void)//对时间
    uchar k;
         for(i=0;i<7;i++)
                   k=time_date/10;
                  time_date=time_date%10;
                  time_date=time_date+k*16;
          write_ds1302(0x8e,0x00);//去除写保护
          for(i=0;i<7;i++)
                   write_ds1302(write_add,time_date);
          write_ds1302(0x8e,0x80);//加写保护
void read_rtc(void)//读出对的时间
          for(i=0;i<7;i++)
                    time_date=read_ds1302(read_add);
void time_pros(void)//处理
        disp[0]=time_date[6]%16;
        disp[1]=time_date[6]/16;
    disp[2]=time_date[5]%16;
        disp[3]=time_date[5]/16;
    disp[4]=time_date[4]%16;
        disp[5]=time_date[4]/16;
void display(void)//显示函数
        uchar j;
        for(j=0;j<6;j++)
            we_set;
                PORTC=table_we[j];
                 we_clr;
                du_set;
            PORTC=table_du[disp[j]];
                  du_clr;
                 delay(5);
void main(void)
     duanko();
         clk_OUT;
         rst_OUT;
     set_rtc();
         while(1)
                 read_rtc();//读出对的时间
                time_pros();//处理
                for(i=0;i<40;i++)
                display();//显示函数
  详情 回复 发表于 2013-1-14 10:34
void read_rtc(void)//读出对的时间 { for(i=0;i  详情 回复 发表于 2013-1-12 09:34
373
回复 楼主 wanghongfaxue 的帖子
          for(i=0;i<7;i++)
这个函数不对,连着读了7次年寄存器,时间肯定不变.
这种问题以后仔细看程序后,再发帖求助
[ 本帖最后由 wudayongnb 于 2013-1-12 09:37 编辑 ]
436
