2503|0
MSP430F149 AD问题 [复制链接]
void Init_AD()
    P6SEL = 0x08;                                     // Enable A/D channel inputs
    ADC12CTL0 = ADC12ON+MSC+SHT0_3;                   // Turn on ADC12, extend sampling time
// ADC12CTL0 |= REF2_5V;                             //选用内部参考电压为2.5V
   ADC12CTL0 &= ~REFON;                               //内部参考电压打开
    ADC12CTL1 = ADC12SSEL_2+CSTARTADD_3+SHP+CONSEQ_2; // Use sampling timer, repeated sequence conseq_0 conseq_2 single  ,  many
//   ADC12MCTL3 = INCH_3+EOS;                          // ref+=AVcc, channel = A3
    ADC12MCTL3=SREF_5;
    ADC12CTL0 |= ENC;                                 // Enable conversions
    ADC12IE=BIT3;
    _EINT();
     /*启动ADC*/
    ADC12CTL0 |= ENC;
    ADC12CTL0 |= ADC12SC;  //启动ADC
#pragma vector=ADC_VECTOR
  __interrupt void AD_IT(void)
    AD3=ADC12MEM3;
    ADC12IFG&=0;
中断里 AD3的值 和寄存器 ADC12MEM3的值 怎么不相等啊
还是一样的 我去掉A3的输入量 AD3还是有值
个人签名相信伙伴 就是相信自己
