2742|2
JK触发器消除毛刺 [复制链接]
module Filter(
input wire clk,
input wire rst_n,
input wire A,
output wire AF
//this module is designed to reduce/eliminate the glitch
//in the input signal of linear ruler or optical encoder
reg A_R1,A_R2,A_R3;
wire A_And_Not, A_Or_Not;
//registers of A and B signal, in order to get a synchronous signal
//and supply a relative clean signal for the post processing
always @(posedge clk or negedge rst_n) begin
if (~rst_n) begin
  A_R1 <= 1'b0;
  A_R2 <= 1'b0;
  A_R3 <= 1'b0;
end
else begin
  A_R1 <= A;
  A_R2 <= A_R1;
  A_R3 <= A_R2;
end
end
assign A_And_Not = ~(A_R1 & A_R2 & A_R3);
assign A_Or_Not  = ~(A_R1 | A_R2 | A_R3);
//using negedge of clk
JKFF74LS109 JKFF74LS109_AInst(
.clk(~clk),
.J(A_Or_Not),
.K_Bar(A_And_Not),
.Q(),
.Q_Bar(AF));
endmodule
//implement a J-K Flipflop, and the behavior model is from 74LS109 chip
module JKFF74LS109(
input wire clk,
input wire J,
input wire K_Bar,
output reg  Q,
output wire Q_Bar);
assign Q_Bar = ~Q;
always @(posedge clk) begin
case ({J, K_Bar})
  2'b00: Q <= 1'b0;
  2'b10: Q <= ~Q;
  2'b01: Q <= Q;
  2'b11: Q <= 1'b1;
  default: Q <= 1'bx;
endcase
end
endmodule
这是消除毛刺的,我不是很理解,谁能帮我讲解一下
此帖出自FPGA/CPLD论坛
没有图,没有注释 ,  详情 回复 发表于 2012-11-19 15:14
6366
4917
没有图,没有注释 ,
此帖出自FPGA/CPLD论坛
RTL图
如题
此帖出自FPGA/CPLD论坛
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
