4141|0
beaglebone心得九:Hello eeworld!!! [复制链接]
今天上午没事,在这调通了UART0,正好板子上的虚拟串口也用的是UART0.
虽然调通了,但费我很长一段时间,为什么呢?
原因是am335X的库太复杂:
除了包含正确的H文件之外还要把相关的C复制到当前的工程中。
比如,这个UART工程中
cpu.c
在\sysem_config\armV7a\cgt\
gpio_v2.c
在\drivers
gpio.c
在\platfom\beaglebone
下面的截图是工程的包含路径:
程序如下:
#include "uart_irda_cir.h"
#include "soc_AM335x.h"
#include "interrupt.h"
#include "beaglebone.h"
#include "hw_types.h"
**              INTERNAL MACRO DEFINITIONS
#define BAUD_RATE_115200          (115200)
#define UART_MODULE_INPUT_CLK     (48000000)
**              INTERNAL FUNCTION PROTOTYPES
static void UartInterruptEnable(void);
static void UART0AINTCConfigure(void);
static void UartFIFOConfigure(void);
static void UartBaudRateSet(void);
static void UARTIsr(void);
**              GLOBAL VARIABLE DEFINITIONS
unsigned char txArray[] = "Hello eewold !!!Thank you very much!!!Good luck!!!\r\n";
unsigned char i;
**              FUNCTION DEFINITIONS
int main()
    /* Configuring the system clocks for UART0 instance. */
    UART0ModuleClkConfig();
    /* Performing the Pin Multiplexing for UART0 instance. */
    UARTPinMuxSetup(0);
    /* Performing a module reset. */
    UARTModuleReset(SOC_UART_0_REGS);
    /* Performing FIFO configurations. */
    UartFIFOConfigure();
    /* Performing Baud Rate settings. */
    UartBaudRateSet();
    /* Switching to Configuration Mode B. */
    UARTRegConfigModeEnable(SOC_UART_0_REGS, UART_REG_CONFIG_MODE_B);
    /* Programming the Line Characteristics. */
    UARTLineCharacConfig(SOC_UART_0_REGS,
                         (UART_FRAME_WORD_LENGTH_8 | UART_FRAME_NUM_STB_1),
                         UART_PARITY_NONE);
    /* Disabling write access to Divisor Latches. */
    UARTDivisorLatchDisable(SOC_UART_0_REGS);
    /* Disabling Break Control. */
    UARTBreakCtl(SOC_UART_0_REGS, UART_BREAK_COND_DISABLE);
    /* Switching to UART16x operating mode. */
    UARTOperatingModeSelect(SOC_UART_0_REGS, UART16x_OPER_MODE);
    /* Performing Interrupt configurations. */
    UartInterruptEnable();
    for(i=0;i     UARTCharPut(SOC_UART_0_REGS, txArray);
    while(1);
下面截图为运行效果图
下面是仿真时的截图:
[ 本帖最后由 ddllxxrr 于 2012-10-28 16:11 编辑 ]
