2122|2
大家帮忙分析下 k为什么置1 以后 就不能改变 [复制链接]
#include
#include
#define         F_CPU        1000000                                                // 单片机主频为7.3728MHz,用于延时子程序和计算定时器初始值
#include
#include
#include
#include                                      //中断信号头文件
//**********************变量区*********************
#define uchar unsigned char
#define uint  unsigned int
#define dird DDRD
#define datd PORTD
#define dira DDRA
#define data PORTA
#define dle0 PORTD &= ~(1 << PD4) //数码管段控制位为0
#define dle1 PORTD |= (1 << PD4)  //数码管段控制位为1
#define wle0 PORTD &= ~(1 << PD5) //数码管位控制位为0
#define wle1 PORTD |= (1 << PD5)  //数码管位控制位为1
uchar ledd[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar ledw[]={0xfe,0xfd,0xfb,0xf7};
uchar dis_buff[4]={0,0,0,0},posit,k;
//**********************函数区****************************
void adc_to_disbuff(uint abc)  //数据放入显示缓存
uchar i;
for(i=0;i<4;i++)
  dis_buff=abc%10;
  abc/=10;
void display(void)             //动态显示
for(posit=0;posit<4;posit++)
  wle1;
  data=0xff;
  wle0;
  dle1;
  data=ledd[dis_buff[posit]];
  dle0;
  data=0xff;
  wle1;
  data=ledw[posit];
  wle0;
ISR(SIG_OUTPUT_COMPARE0)      //定时器1比较中断
k=1;
void main(void)
uint j;
dira=0xef;
data=0xef;
dird=0x3f;
datd=0xff;
TCCR0=0X0A;                   //定义定时器0工作方式
OCR0=249;
TIMSK=0X02;
SREG|=0X80;
while(1)
  if(k)
   display();
   k=0;
  详情 回复 发表于 2012-11-21 16:26
:rose: :rose:
