TI Sitara入门资料分享4-Linux下AM335X的GPIO控制
Linux下AM335X的GPIO控制
作者: chenzhufly --转完才发现是论坛里的元老哦,嘿嘿他的微博,里面东东很多,大家去看看 http://blog.chinaunix.net/uid-730738-id-3266698.html ( 转载 )
一路走来,熟悉硬件系统,搭建软件开发环境,编译Linux系统等等,现在也该到对硬件做一些事情了,这是我这几天的研究心得,与君共享。
1. GPIO 的 char 型驱动,这里主要就是点个灯,感受一下驱动的设计和硬件的控制驱动程序:
复制内容到剪贴板 代码:#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define NAME \"leds\"
#define GPIO_TO_PIN(bank, gpio) (32 * (bank) + (gpio))
static int major =251;//定义主设备号
void led_on(void)
gpio_set_value(GPIO_TO_PIN(1,22), 1);
void led_off(void)
gpio_set_value(GPIO_TO_PIN(1,22), 0);
void led_init(void)
int result;
/* Allocating GPIOs and setting direction */
result = gpio_request(GPIO_TO_PIN(1,22), \"Leds\");//usr1
if (result != 0)
printk(\"gpio_request(1_22) failed!\n\");
result = gpio_direction_output(GPIO_TO_PIN(1,22), 1);
if (result != 0)
printk(\"gpio_direction(1_22) failed!\n\");
struct light_dev
struct cdev cdev;
unsigned char value;
struct light_dev *light_devp;
MODULE_AUTHOR(\"chenzhufly\");
MODULE_LICENSE(\"Dual BSD/GPL\");
// 打开和关闭函数
int light_open(struct inode *inode,struct file *filp)
struct light_dev *dev;
// 获得设备结构体指针
dev = container_of(inode->i_cdev,struct light_dev,cdev);
// 让设备结构体作为设备的私有信息
filp->private_data = dev;
return 0;
int light_release(struct inode *inode,struct file *filp)
return 0;
// ioctl
int light_ioctl(struct file *filp,unsigned int cmd,
unsigned long arg)
struct light_dev *dev = filp->private_data;
switch(cmd)
case 0:
dev->value = 0;
led_off();
break;
case 1:
dev->value = 1;
led_on();
break;
default:
return -ENOTTY;
// break;
return 0;
struct file_operations light_fops =
.owner = THIS_MODULE,
.unlocked_ioctl = light_ioctl,
.open = light_open,
.release = light_release,
// 模块加载函数
int light_init(void)
int ret;
led_init();
printk(KERN_ALERT \"led modules is install\n\");
ret=register_chrdev(major,NAME,&light_fops);
if(ret<0)
printk(\"unable to register myled driver!\n\");
return ret;
return 0;
// 模块卸载函数
void light_cleanup(void)
unregister_chrdev(major,NAME);
printk(\"Goodbye,cruel world!\n\");
module_init(light_init);
module_exit(light_cleanup);
应用程序:
#include
#include
#include
#include
#include
#include
int main(int argc, char * argv)
int i, n, fd;
fd = open(\"/dev/leds\", O_RDWR);
if (fd < 0)
printf(\"can't open /dev/leds!\n\");
exit(1);
while (1) {
ioctl(fd, 1, 1);
sleep(1);
ioctl(fd, 0, 1);
sleep(1);
close(fd);
return 0;
Makefile 文件:
复制内容到剪贴板 代码:ARCH=arm
CROSS_COMPILE=/home/chenzhufly/beaglebone/linux-devkit/bin/arm-arago-linux-gnueabi-
obj-m := leds.o
KDIR := /home/chenzhufly/beaglebone/board-support/linux-3.1.0-psp04.06.00.03.sdk
PWD := $(shell pwd)
default:
make -C $(KDIR) M=$(PWD) ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE) modules
app: leds_test.c
$(CROSS_COMPILE)gcc -o leds_test leds_test.c
clean:
$(MAKE) -C $(KDIR) M=$(PWD) clean
leds.sh脚本
复制内容到剪贴板 代码:insmod leds.ko
mknod /dev/leds c 251 0
./leds_test
2. 使用echo命令,这个我在前面也说过
复制内容到剪贴板 代码:点亮usr1
root@beaglebone:~# echo 1 >
/sys/class/leds/beaglebone::usr1/brightness
关闭usr1
root@beaglebone:~# echo 0 > /sys/class/leds/beaglebone::usr1/brightness
3. 做个应用程序实现流水灯功能吧
#include
#include
#include
#include
#include
#define LED1 \"/sys/class/leds/beaglebone::usr1/brightness\" // usr1 led
#define LED2 \"/sys/class/leds/beaglebone::usr2/brightness\" // usr2 led
#define LED3 \"/sys/class/leds/beaglebone::usr3/brightness\" // usr3 led
int main(void)
int f_led1 = open(LED1, O_RDWR);
int f_led2 = open(LED2, O_RDWR);
int f_led3 = open(LED3, O_RDWR);
unsigned char dat1, dat2, dat3;
unsigned char i = 0;
if (f_led1 < 0)
printf(\"error in open %s\",LED1);
return -1;
if (f_led2 < 0)
printf(\"error in open %s\",LED2);
return -1;
if (f_led3 < 0)
printf(\"error in open %s\",LED3);
return -1;
//add 10 times
for(i=1; i<30; i++)
dat1 = ((i%3) == 1) ? '1' : '0';
dat2 = ((i%3) == 2) ? '1' : '0';
dat3 = ((i%3) == 0) ? '1' : '0';
write(f_led1, &dat1, sizeof(dat1));
write(f_led2, &dat2, sizeof(dat2));
write(f_led3, &dat3, sizeof(dat3));
usleep(300000);
// all the bright
dat1 = '1';
dat2 = '1';
dat3 = '1';
[ 本帖最后由 shower.xu 于 2012-10-26 11:50 编辑 ]
