4359|4
316
AM335x主要特性,方框图及其评估模块(整理) [复制链接]
[size=+0]支持eeworld,支持TI,谢谢这次活动!
TI 公司的TMDXEVM3358是AM335x ARM Cortex-A8微处理器的评估模块,能对AM335x 处理器(AM3352, AM3354, AM3356, AM3358) 进行测试评估和开发,包括EVM基板,子板和LCD显示模块,主要用于游戏机外设,售货机,家庭和工业自动化,称重仪,消费类医疗设备,教育控制台,打印机,高挡玩具和智能收费系统.本文介绍了AM335x 主要特性,方框图,AM335x评估模块(EVM)系统框图,基板和子板方框图,电路图以及PCB布局图.
[size=+0]The AM335x microprocessors, based on the ARM Cortex-A8, are enhanced with image, graphics processing, peripherals and industrial INTERFACE options such as EtherCAT and PROFIBUS. The DEVICE supports the following high-level operating systems (HLOSs) that are available free of charge from TI:
[size=+0]◎ Linux
[size=+0]◎ Windows CE
[size=+0]◎ Android
[size=+0]The AM335x microrocessor contains these subsystems:
[size=+0]◎ Microprocessor unit (MPU) subsystem based on the ARM Cortex-A8 microprocessor.
[size=+0]◎ POWERVR SGX Graphics Accelerator subsystem for 3D graphics acceleration to support DISPLAY and gaming effects.
[size=+0]◎ Programmable Real-Time Unit Subsystem (PRUSS) enables the user to create a variety of DIGITAL resources beyond native peripherals of the device. In addition, the PRUSS is separate from the ARM core. This allows independent operation and clocking to give the device greater flexibility in complex system solutions.
[size=+0]AM335x 主要特性:
[size=+0][size=+0][size=+0][size=+0][size=+0][size=+0]
[size=+0]AM335x 应用:
[size=+0]◎ Gaming Peripherals
[size=+0]◎ Connected Vending Machines
[size=+0]◎ Home and Industrial AUTOMATION
[size=+0]◎ Weighing Scales
[size=+0]◎ Consumer Medical Appliances
[size=+0]◎ Educational Consoles
[size=+0]◎ Printers
[size=+0]◎ ADVANCED Toys
[size=+0]◎ Smart Toll Systems
[size=+0]
[size=+0][size=+0]
[size=+0]图1.AM335x 功能方框图
[size=+0]AM335x评估模块(EVM)
[size=+0]The AM335x EVALUATION MODULE (EVM) enables developers to immediately start evaluating AM335x processors (AM3352, AM3354, AM3356, AM3358) and begin building applications such as portable navigation, portable gaming and home/building automation, among others.
[size=+0]The AM335x GENERAL purpose EVM is a standalone test, development, and evaluation module system that enables developers to write SOFTWARE and develop HARDWARE around an AM335x processor subsystem.
[size=+0]The main elements of the AM335x subsystem are already available on the base board of the EVM, which gives developers the basic resources needed for most general purpose type projects that encompass the AM335x as the main processor. Additional typical type peripherals are built into the EVM such as MEMORY, SENSORS, LCD, Ethernet PHY, etc. so that prospective systems can be modeled quickly without significant additional hardware resources.
[size=+0]The System View of the AM335x General Purpose EVM consists the baseboard, daughterboard, and LCD display board stacked together and connected through STANDARD throughhole connectors. See the pictures below of the EVM.
[size=+0]图2.AM335x评估模块(EVM)外形图
[size=+0]图3.AM335x评估模块(EVM)系统框图
[size=+0]图4.AM335x 15x15 基板方框图
[size=+0]图5.AM335x通用子板方框图
[size=+0]图6.AM335x 15x15 基板电路图(1)
[size=+0]图7.AM335x 15x15 基板电路图(2)
[size=+0]图8.AM335x 15x15 基板电路图(3)
[size=+0]图9.AM335x 15x15 基板电路图(4)
[size=+0]图10.AM335x 15x15 基板电路图(5)
[size=+0]图11.AM335x 15x15 基板电路图(6)
[size=+0]图12.AM335x 15x15 基板电路图(7)
[size=+0]图13.AM335x 15x15 基板电路图(8)
[size=+0]图14.AM335x 15x15 基板电路图(9)
[size=+0]图15.AM335x 15x15 基板电路图(10)
[size=+0]图16.AM335x 15x15 基板电路图(11)
[size=+0]图17.AM335x 15x15 基板电路图(12)
[size=+0]图18.AM335x 15x15 基板电路图(13)
[size=+0]图19.AM335x 15x15 基板电路图(14)
[size=+0]图20.AM335x EVM通用子板电路图(1)
[size=+0]图21.AM335x EVM通用子板电路图(2)
[size=+0]图22.AM335x EVM通用子板电路图(3)
[size=+0]图23.AM335x EVM通用子板电路图(4)
[size=+0]图24.AM335x EVM通用子板电路图(5)
[size=+0]图25.AM335x EVM通用子板电路图(6)
[size=+0]图26.AM335x EVM通用子板电路图(7)
[size=+0]图27.AM335x EVM通用子板电路图(8)
[size=+0]图28.AM335x EVM通用子板电路图(9)
[size=+0]图29.AM335x EVM通用子板电路图(10)
[size=+0]图30.AM335x EVM通用子板电路图(11)
[size=+0]图31.AM335x EVM通用子板电路图(12)
[size=+0]图32.AM335x EVM通用子板电路图(13)
[size=+0]图33.AM335x EVM基板PCB元件布局图:顶层
[size=+0]图34.AM335x EVM基板PCB元件布局图:底层
[size=+0]图35.AM335x EVM通用子板PCB元件布局图:顶层
[size=+0]图36.AM335x EVM通用子板PCB元件布局图:底层
全都E文  还是官方文档截图啊  详情 回复 发表于 2012-10-23 22:48
3238
166
224
全都E文  还是官方文档截图啊
刚好大家可以称机会讨论一下!  详情 回复 发表于 2012-10-24 00:11
316
这个只是一个整体的架构描述,中间很常见的就没有翻译!
316
原帖由 wyzamazon 于 2012-10-23 22:48 发表
全都E文  还是官方文档截图啊
刚好大家可以称机会讨论一下!
