3873|6
36
有关LwIP中IP地址的定义 [复制链接]
开始的时候PC作为服务器,无法接受数据,经过几天,终于发现了错误所在,可是不知道为什么,麻烦各位帮我看看!
const static unsigned char test_data[]="This is LwIP TCP Client 在Luminary Cortex-M3上的测试!\r\n";
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_nvic.h"
#include "inc/hw_types.h"
#include "driverlib/ethernet.h"
#include "driverlib/flash.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "utils/locator.h"
#include "utils/lwiplib.h"
#include "utils/uartstdio.h"
#include "utils/ustdlib.h"
#include "grlib/grlib.h"
// Defines for setting up the system clock.
#define SYSTICKHZ               100
#define SYSTICKMS               (1000 / SYSTICKHZ)
#define SYSTICKUS               (1000000 / SYSTICKHZ)
#define SYSTICKNS               (1000000000 / SYSTICKHZ)
// Interrupt priority definitions.  The top 3 bits of these values are
// significant with lower values indicating higher priority interrupts.
#define SYSTICK_INT_PRIORITY    0x80
#define ETHERNET_INT_PRIORITY   0xC0
//the ip of PC
#define ip_PC  {192,168,0,101}
static const unsigned char pcIPAddress[]=ip_PC;
//address for Mac,IP,Mack,gateway address
#define My_Mac_ID         {0X00,0x14,0x97,0x0F,0x1D,0xE3}  //存储以太网控制器的物理地址,即MAC地址
#define MY_IP_ID               {192,168,0,100}                   //以太网通信的IP地址
#define IP_MARK_ID           {255,255,255,0}                           //255.255.255.0,子网掩码
#define MY_GATEWAY_ID   {192,168,0,1}                     //以太网通信的网关地址
static const unsigned char pucMACAddress[]=My_Mac_ID;
static const unsigned char IPAddress[] = MY_IP_ID;
static const unsigned char NetMaskAddr[] = IP_MARK_ID;
static const unsigned char GwWayAddr[] = MY_GATEWAY_ID;
//define a tcp_pcb struct for the tcp_write
static struct tcp_pcb *g_psPCB = NULL;
//a struct for the state of the pcb
typedef struct
    unsigned long ulRetryCount;
    tBoolean bCONTROLSent;
tAPPState;
//this function will used after the connection is builded
static err_t tcp_trans(void *arg,struct tcp_pcb *tpcb,err_t err)
        tAPPState *pState;
          pState = arg;
          if((err == ERR_OK) && (test_data != NULL))
             tcp_write(tpcb,test_data,sizeof(test_data),0);
         if((err == ERR_OK) && (test_data == NULL))
        // Close the connection.
        mem_free(pState);
        tcp_close(tpcb);
    return ERR_OK;
// The interrupt handler for the SysTick interrupt.
void
SysTickIntHandler(void)
    // Call the lwIP timer handler.
    lwIPTimer(SYSTICKMS);
//this is the main function
int main()
        struct ip_addr ulIPAddr,ulNetMask,ulGWAddr,pIPAddress;
           struct tcp_pcb *tcp_pcb_conn;
    // Set the system clock to run at 50MHz from the PLL.
    SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |
                   SYSCTL_XTAL_16MHZ);
    // Enable and Reset the Ethernet Controller.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ETH);
    SysCtlPeripheralReset(SYSCTL_PERIPH_ETH);
        // Enable Port F for Ethernet LEDs.
    //  LED0        Bit 3   Output
    //  LED1        Bit 2   Output
    GPIOPinTypeEthernetLED(GPIO_PORTF_BASE, GPIO_PIN_2 | GPIO_PIN_3);
    // Configure SysTick for a periodic interrupt.
    SysTickPeriodSet(SysCtlClockGet() / SYSTICKHZ);
    SysTickEnable();
    SysTickIntEnable();
    // Enable processor interrupts.
    IntMasterEnable();
    // Initialze the lwIP library, using the stacic ip.
        IP4_ADDR(&ulIPAddr,IPAddress[3],IPAddress[2],IPAddress[1],IPAddress[0]);
    IP4_ADDR(&ulNetMask,NetMaskAddr[3],NetMaskAddr[2],NetMaskAddr[1],NetMaskAddr[0]);
    IP4_ADDR(&ulGWAddr,GwWayAddr[3],GwWayAddr[2],GwWayAddr[1],GwWayAddr[0]);
        IP4_ADDR(&pIPAddress,pcIPAddress[3],pcIPAddress[2],pcIPAddress[1],pcIPAddress[0]);
    lwIPInit(pucMACAddress,ulIPAddr.addr, ulNetMask.addr, ulGWAddr.addr, IPADDR_USE_STATIC);
        //create a TCP connection betweent LM and PC
        tcp_pcb_conn=tcp_new();
        tcp_bind (tcp_pcb_conn,&ulIPAddr, 1026);
        tcp_connect(tcp_pcb_conn,&pIPAddress,1026,tcp_trans);
        while(1)
上面是开始的程序,后来发现PC机IP的定义和初始化修改后,问题解决了!
大体如下:
开始时候的定义:
#define ip_PC  {192,168,1,101}
这样再通过pIPAddress进行传递
新的程序是这样的:
IP4_ADDR(&pIPAddress,192,168,1,101);
再通过pIPAddress进行传递PC机的IP
我感觉没有什么变化,可是不修改就无法接受数据,麻烦各位看看是为什么,谢谢!
IP4_ADDR(&pIPAddress,pcIPAddress[3],pcIPAddress[2],pcIPAddress[1],pcIPAddress[0]); 那这里边顺序你觉得是对的吗?  详情 回复 发表于 2012-8-27 09:33
1803
注意这里边 IP 地址的顺序。
我感觉两种写法一样啊。。位置好像没错吧!  详情 回复 发表于 2012-8-23 14:55
36
回复 沙发 Study_Stellaris 的帖子
我觉得位置是有问题的,试试IP4_ADDR(&pIPAddress,101,1,168,192);  详情 回复 发表于 2012-8-24 18:12
1803
回复 板凳 lvfeihi 的帖子
我的意思是: 开始是这样写的,不行! #define ip_PC {192,168,1,101} static const unsigned char pcIPAddress[]=ip_PC; IP4_ADDR(&pIPAddress,pcIPAddress[3],pcIPAddress[2],pcIPAddress[1],pcIPAddress[0]  详情 回复 发表于 2012-8-26 20:52
36
回复 4楼 Study_Stellaris 的帖子
我的意思是:
开始是这样写的,不行!
这样再通过pIPAddress进行传递,这样写不可以!
新的程序是可以的!
再通过pIPAddress进行传递PC机的IP,这样是可以的!
1803
回复 5楼 lvfeihi 的帖子
那这里边顺序你觉得是对的吗?
应该是对的,这个格式和ARM的IP格式是一样的!  详情 回复 发表于 2012-8-27 12:35
36
回复 6楼 Study_Stellaris 的帖子
