3362|1
按键控制步进马达正反转 [复制链接]
include
#define uchar      unsigned char
#define uint       unsigned int
#define  dianji   P2
void  delay_50us(uint t);
uchar  F_zhuan[8]={0xE2,0xE6,0xE4,0xEC,0xE8,0xF8,0xF0,0xF2};
uchar  B_zhuan[8]={0xF2,0xF0,0xF8,0xE8,0xEC,0xE4,0xE6,0xE2};
sbit key1 = P0^6;
sbit key2 = P0^7;
void zheng(void)
  uint i;
  if(key2==0)
   for(i=0;i<8;i++)
     dianji=B_zhuan;
     delay_50us(100);
void fan(void)
  uint i;
  if(key1==0)
   for(i=0;i<8;i++)
     dianji=F_zhuan;
     delay_50us(100);
void main()
while(1)
   dianji=0x00;
   if(key1==1)
    while(!key1)
    fan();
   if(key2==1)
    while(!key2)
    zheng();
  uchar j;
  for(;t>0;t--)
   for(j=19;j>0;j--);
哪错了,按键有时有效又时失灵
此帖出自51单片机论坛
程序没有错,就是按键是,应有一个去抖动,就是延时一下,一般20MS  详情 回复 发表于 2012-8-22 08:49
此帖出自51单片机论坛
