2554|0
mega128 HC595 驱动四位一体数码管 [复制链接]
这是我的程序#include
#define SS                                0
#define SCK                                1
#define MOSI                           2
#define MISO                    3
#define OE                                7
#define SS_H()                        PORTB|=(1< #define SS_L()                        PORTB&=~(1< #define CLR_BIT(x,y)        x&=~(1< unsigned int i;
unsigned char Seg7_Data[]={0x3f,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71,0x00};
void delay_1us(void)                 //1us延时函数
   asm("nop");
void delay_nus(unsigned int n)       //N us延时函数
   unsigned int i=0;
   for (i=0;i    delay_1us();
void delay_1ms(void)                 //1ms延时函数
   unsigned int i;
   for (i=0;i<1140;i++);
void delay_nms(unsigned int n)       //N ms延时函数
   unsigned int i=0;
   for (i=0;i    delay_1ms();
void SPI_MasterTransmit(unsigned char Data)
          SPDR=Data;
          while(!(SPSR&(1<           //CLR_BIT(SPSR,SPIF);
/*void HC_595_Init()
          unsigned char data;
          for(data=0;data<18;data++)
          SS_L();
          SPI_MasterTransmit(Seg7_Data[data]);
          SS_H();
          delay(1000);
void main()
         int i;
          while(1)
          for(i=0;i<17;i++)
          DDRC|=(1<           PORTC&=~(1<           DDRB=0xff;
          PORTB|=0xff;
          DDRB|=(1<           SPCR|=(1<           SS_L();
          //delay_1us();
          SPI_MasterTransmit(Seg7_Data);
          //delay_nus(10);
      SS_H();
          //delay_nus(10);
          delay_nms(1000);
这是原理图的地址,请大家帮帮忙啊
