2700|0
为什么Timer不中断啊 [复制链接]
程序功能:MCU的片内ADC对P6.0端口的电压进行转换
          将模拟电压值显示在1602液晶上。
#include
//typedef unsigned char uchar;
//typedef unsigned int  uint;
#define   Num_of_Results   32
#define   uchar  unsigned char
#define   uint   unsigned int
uint MAX=0;
uint index1=0,index2=0,A,flag=0x01;
static uint result1[Num_of_Results],result2[Num_of_Results];    //保存ADC转换结果的数组                                                     // is not used for anything.
void Trans_val(uint Hex_Val);
/************************主函数****************************/
void main(void)
  uint i;
  WDTCTL = WDTPW+WDTHOLD;                   //关闭看门狗
  BCSCTL1 &= ~XT2OFF;                       // XT2= HF XTAL
  do
  IFG1 &= ~OFIFG;                           // Clear OSCFault flag
  for (i = 0xFF; i > 0; i--);               // Time for flag to set
  while ((IFG1 & OFIFG));                   // OSCFault flag still set?
  BCSCTL2 |= SELM_2+SELS;
  P6DIR = 0XFF;
  P6DIR |= BIT2;P6OUT |= BIT2;              //关闭电平转换
  P6SEL |= 0x01;                            // 使能ADC通道
  P6SEL |= 0X01;
  ADC12CTL0 = ADC12ON+SHT0_2+REFON+MSC+REF2_5V; // Turn on and set up ADC12
  ADC12MCTL0 = SREF_1 + INCH_0;                      // Vr+=Vref+
  ADC12MCTL1 = SREF_1 + INCH_1 + EOS;
  ADC12CTL1 |= SHP+CONSEQ_3;                 // 使用采样定时器 /*
  ADC12IE = 0x02;                           // 使能ADC中断
  ADC12CTL0 |= ENC;                         // 使能转换
  ADC12CTL0 |= ADC12SC;                     // 开始转换*/
  CCTL0 |= CCIE;
  TACTL = TASSEL_2 + MC_1+ TACLR + TAIE;
                               // CCR0 interrupt enabled
  CCR0 = 1000-1;
           // INCLK, upmode
_BIS_SR(LPM0_bits + GIE);                 // Enter LPM3 w/ interrupt
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A (void)
  P1OUT^=0x01;                            // Toggle P1.0
#pragma vector=ADC_VECTOR
__interrupt void ADC12ISR (void)
  uint temp;
  if(flag==1)
    result1[index1++] = ADC12MEM0;               // Move results
    if(index1 == Num_of_Results)
        temp=MAX;
        uchar i;
        unsigned long temp= 0;
        for(i=0;i<32;i++)
         if(temp)
           temp=result1;
        MAX=temp;
        index1=0;
  else
   result1[index2++]=ADC12MEM1;
   if(index2 == Num_of_Results)
        temp=MAX;
        uchar i;
        for(i=0;i<32;i++)
         if(temp)
           temp=result1;
        MAX=temp;
        index2=0;
