2767|0
ADC10采集1KHz的正弦信号误差很大 [复制链接]
贴出我的程序,单通的,测直流信号还可以,800mv 1KHz的正弦信号误差十分大,只显示0.1XX(XX是两个变化很快的数字),求解是什么原因?怎么解决?
#include "msp430g2553.h"
#include "12864_1.h"
unsigned int s1 = 0;
unsigned char i = 0;
unsigned char flag = 0;
float sum = 0;
float voltage = 00.000;
unsigned char s2[]={"error"};
void main(void)
WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  ADC10CTL0 = ADC10SHT_2 + ADC10ON + ADC10IE; // ADC10ON, interrupt enabled
  ADC10CTL1 = INCH_1;                       // input A1
  ADC10AE0 |= 0x02;                         // PA.1 ADC option select
  P2DIR |=BIT3+BIT4;
  init_lcd();
  for (;;)
    ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
    __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit
    voltage = (3560/1023)*sum/1000;
    if((flag == 1)&&(voltage < 3.3))
        wr_float(0,0,voltage);
       // delay_ms(200);
        flag = 0;
    if(voltage >= 3.3)
        clr_lcd(0,0,6);
        wr_string(0,0,s2);
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
  i++;
  s1 = ADC10MEM;
  sum = sum + s1;
  if(i == 10)
      i = 0;
      sum = sum/10;
      flag = 1;
  __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
