2884|2
ADC12单通道转换程序 [复制链接]
采用数码管显示转换的电压
#include "delay.h"
#define   Num_of_Results   32
static uint results[Num_of_Results];
uchar d[11]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
uchar d1[11]={0xbf,0x86,0xdb,0xcf,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
uchar a[8]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
void main()
  // Stop watchdog timer to prevent time out reset
        uchar j;
        WDTCTL = WDTPW + WDTHOLD;
        //使用外部高频晶体振荡器
        BCSCTL1&=~XT2OFF;
        do{
          IFG1&=~OFIFG;
          for(j=0XFF;j>0;j--);
        }while((IFG1&OFIFG));
        BCSCTL2|=SELM_2;
        P6DIR&=~BIT0;
        P6SEL |= BIT0;  // 使能ADC通道
        ADC12CTL0 = ADC12ON+SHT0_8+MSC;
        // ADC12ON打开ADC,
        //SHT0_8设置采样时间,合适即可
        //MSC设置多次采样
        ADC12CTL1 = CSTARTADD_0+SHP+CONSEQ_2;
        // CSTARTADD_3让采样结果保存在ADC12MEM3中
        //CONSEQ_2单通道多次转换
        //SHP使用采样定时器
        ADC12IE = BIT0;// 中断允许,IFG置位后会进入中断服务程序
        //ADC12MCTL3=INCH_3;//通道A1 默认SERF为0,即参考0-AVCC
        ADC12CTL0 |= ENC+ADC12SC;  // 使能转换并且开始转换
        ADC12IFG=0;
        _EINT();//打开中断
while(1);
//ADC中断服务函数,在这里用多次平均的
#pragma vector=ADC_VECTOR
__interrupt void ADC12ISR (void)
      uint i,j;
      uchar ptr[4];
P4DIR=0XFF;//p4作为输出
        P5DIR=0XFF;
        P6DIR=0XFF;
  static uint index = 0;
  results[index++] = ADC12MEM0;  // 必须和CSTARTADD_3一样
  if(index == Num_of_Results)
        unsigned long sum = 0,real;
        index = 0;
        for(i = 0; i < Num_of_Results; i++)
            sum += results;
        sum >>= 5;                            //除以32求得平均值
        real=3300*sum/4095;//扩大1000倍
    ptr[3] = real / 1000;
    ptr[2] = (real - ptr[3]*1000)/100;
    ptr[1] = (real - ptr[3]*1000 - ptr[2]*100)/10;
    ptr[0] = (real - ptr[3]*1000 - ptr[2]*100 - ptr[1]*10);
        for(i=0;i<4;i++)
                P4OUT=d[10];
                P5OUT|=BIT5;//设置p5.5为高电平
                P4OUT=a;
                P5OUT^=BIT5;//设置p5.5为低电平
                P6OUT|=BIT6;
                if(i==3)
                P4OUT=d1[ptr];
                else
                P4OUT=d[ptr];
                for(j=0;j<1000;j++);
                P4OUT=d[10];
                P6OUT^=BIT6;
  ADC12IFG=0;
学习了,资料很好,感谢分享。学习中缺失中的资料,有用。   详情 回复 发表于 2024-10-14 22:24
161
顶起
63
禁止发言
