2727|1
大侠帮忙,很急 [复制链接]
Error[e16]:Segment CSTACK(size:0x64 align:0x1)is too long for segment definition, At least 0x1e more bytes needed. The problem occurred while processing the segment placement command"-Z(DATA)CSTACK+_STACK_SIZE#",where at the moment of placement the avaiable memory ranges ware "CODE:2BA-2FF"
Reserved ranges relevant to this placement:
200-285 DATA16_I
286-2b9 DATA16_Z
2ba-2ff CSTACK
error while running Linker
很急 谁能解决下
ram不够,可以将大数组存到rom中,我也刚遇到这个问题,在查呢,网上是这么说的,还可以将option中的stack/heap改小一些  详情 回复 发表于 2012-8-3 01:08
118
