刚看以G2553的例程 ADC10_16 其中有一句 ADC10SA = (unsigned int)&TACCR1; // Data transfer location 其中 TACCR1 的初值是 512 经运行后 ADC10SA的值变为372后不再变了 但是TACCR1的值变成563 问这是怎么个原理?这事不科学啊。。程序贴在下面 求解答另外 程序开始中的注释 直接传输code到TACCR1,这句什么意思?这会是TACCR1值变的原因吗?
//****************************************************************************** // MSP430G2x33/G2x53 Demo - ADC10, DTC Sample A0 -> TA1, AVcc, DCO // // Description: Use DTC to sample A0 with reference to AVcc and directly // transfer code to TACCR1. Timer_A has been configured for 10-bit PWM mode. // TACCR1 duty cycle is automatically proportional to ADC10 A0. WDT_ISR used // as a period wakeup timer approximately 45ms based on default ~1.2MHz // DCO/SMCLK clock source used in this example for the WDT clock source. // Timer_A also uses default DCO. // // MSP430G2x33/G2x53 // ----------------- // /|\| XIN|- // | | | // --|RST XOUT|- // | | // >---|P1.0/A0 P1.2|--> TACCR1 - 0-1024 PWM // // D. Dang // Texas Instruments Inc. // December 2010 // Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10 //****************************************************************************** #include "msp430g2553.h"
void main(void) { WDTCTL = WDT_MDLY_32; // WDT ~45ms interval timer IE1 |= WDTIE; // Enable WDT interrupt ADC10CTL0 = ADC10SHT_2 + ADC10ON; ADC10AE0 |= 0x01; // P1.0 ADC option select ADC10DTC1 = 0x001; // 1 conversion P1DIR |= 0x04; // P1.2 = output P1SEL |= 0x04; // P1.2 = TA1 output TACCR0 = 1024 - 1; // PWM Period TACCTL1 = OUTMOD_7; // TACCR1 reset/set TACCR1 = 512; // TACCR1 PWM Duty Cycle TACTL = TASSEL_2 + MC_1; // SMCLK, upmode
while(1) { __bis_SR_register(LPM0_bits + GIE); // LPM0, WDT_ISR will force exit ADC10SA = (unsigned int)&TACCR1; // Data transfer location ADC10CTL0 |= ENC + ADC10SC; // Start sampling } }
#pragma vector = WDT_VECTOR __interrupt void WDT_ISR(void) { __bic_SR_register_on_exit(LPM0_bits); // Exit LPM0 }
[ 本帖最后由 taotiezh 于 2012-7-20 16:14 编辑 ]
