5347|0
STR-CC2540-BLE 4.0/低功耗蓝牙透传模块 [复制链接]
General Description
The CC2540 module is a cost-effective, low-power, true system-on-chip (SoC) for Bluetooth low energy applications. It enables robust BLE master or slave nodes to be built with very low total bill-of-material costs. The CC2540 combines an excellent RF transceiver with an industry-standard enhanced 8051 MCU, in-system programmable flash memory, 8-KB RAM, and many other powerful supporting features and peripherals.
The CC2540 is suitable for systems where very low power consumption is required. Very low-power sleep modes are available. Short transition times between operating modes further enable low power consumption.
Features and Benefits
Bluetooth low energy technology Compatible
 Excellent Link Budget (up to 97 dB),
 Enabling Long-Range Applications
 Accurate Digital RSSI
 Compliance With FCC & CE standard
 High-Performance and Low-Power 8051 MCU core
 Battery Monitor and Temperature Sensor
 Sample Applications and Profiles
 Full-Speed USB Interface
 AES Security Coprocessor
Technical Parameters
ITEM
TEST REQUIREMENT
 REMARKS
Voltage supply
2.03.6V DC
Center frequency
24002483.5MHz
Programmable
Frequency error
±20KHz
Modulation
O-QPSK
Output power
4.5dBm
Programmable
Receiving sensitivity
-93dBm
High gain Mode
Receiving current
24mA
High gain mode
Receiving current
21mA
Standard mode
Transmitting current
35mA
TX Power
26mA
TX Power -6dBm
Sleep consumption At power mode3
0.4uA
 Connection-less stat
Transmit distance
>50M
BER<0.1%
Antenna
50ohm
Temperature range
-2085°C
module size
15*25mm
2.4-GHz Bluetooth low energy Systems
 Mobile Phone Accessories
 Sports and Leisure Equipment
 Consumer Electronics
 Human Interface Devices (Keyboard, Mouse Remote Control)
 USB Dongles
 Health Care and Medical
