3540|2
msp430ADC采样问题 [复制链接]
我想用149芯片的P6口进行采样,现在不知道怎么回事只能让P6.0口采样,怎么让P6.1口采样,怎么设置,我弄了一上午了
#include  <msp430x14x.h>#define   Num_of_Results   8static unsigned int A0results[Num_of_Results];  // These need to be global instatic unsigned int A1results[Num_of_Results];  // this example. Otherwise, thestatic unsigned int A2results[Num_of_Results];  // compiler removes them becausestatic unsigned int A3results[Num_of_Results];  // they are not usedvoid main(void){  WDTCTL = WDTPW+WDTHOLD;                   // Stop watchdog timer  P6SEL = 0x0F;                             // Enable A/D channel inputs  ADC12CTL0 = ADC12ON+MSC+SHT0_8;           // Turn on ADC12, extend sampling time                                            // to avoid overflow of results  ADC12CTL1 = SHP+CONSEQ_3;                 // Use sampling timer, repeated sequence  ADC12MCTL0 = INCH_0;                      // ref+=AVcc, channel = A0  ADC12MCTL1 = INCH_1;                      // ref+=AVcc, channel = A1  ADC12MCTL2 = INCH_2;                      // ref+=AVcc, channel = A2  ADC12MCTL3 = INCH_3+EOS;                  // ref+=AVcc, channel = A3, end seq.  ADC12IE = 0x08;                           // Enable ADC12IFG.3  ADC12CTL0 |= ENC;                         // Enable conversions  ADC12CTL0 |= ADC12SC;                     // Start conversion  _BIS_SR(LPM0_bits + GIE);                 // Enter LPM0, Enable interrupts}#pragma vector=ADC12_VECTOR__interrupt void ADC12ISR (void){  static unsigned int index = 0;  A0results[index] = ADC12MEM0;             // Move A0 results, IFG is cleared  A1results[index] = ADC12MEM1;             // Move A1 results, IFG is cleared  A2results[index] = ADC12MEM2;             // Move A2 results, IFG is cleared  A3results[index] = ADC12MEM3;             // Move A3 results, IFG is cleared  index = (index+1)%Num_of_Results;         // Increment results index, modulo; Set Breakpoint here}复制代码  详情 回复 发表于 2012-7-18 15:11
5014
裸片初长成(初级)
//                 MSP430F149
//   Vin0 -->|P6.0/A0          |
//   Vin1 -->|P6.1/A1          |
//   Vin2 -->|P6.2/A2          |
//   Vin3 -->|P6.3/A3          |
5014
裸片初长成(初级)
  1. #include <msp430x14x.h>
    void main(void)
复制代码
【直播时间】5月28日(周三)上午10:00
