simon@simon-laptop:~/Work/ti-sdk-am335x-evm-05.04.01.00/bin$ sudo ./create-sdcard.sh
This script will create a bootable SD card from custom or pre-built binaries.
The script must be run with root permissions and from the bin directory of
the SDK
Example:
Formatting can be skipped if the SD card is already formatted and
partitioned properly.
Availible Drives to write images to:
# major minor size name
1: 8 16 3813376 sdb
Enter Device Number: 1
sdb was selected
Checking the device is unmounted
unmounted /dev/sdb1
unmounted /dev/sdb2
unmounted /dev/sdb3
sdb1 sdb2 sdb3
72261 923737 2795310
Detected device has 3 partitions already
Re-partitioning will allow the choice of 2 or 3 partitions
Would you like to re-partition the drive anyways [y/n] : y
Now partitioning sdb ...
Select 2 partitions if only need boot and rootfs (most users)
Select 3 partitions if need SDK & CCS on SD card. This is usually used
by device manufacturers with access to partition tarballs.
****WARNING**** continuing will erase all data on sdb
Number of partitions needed [2/3] : 2
Now partitioning sdb with 2 partitions...
Now making 2 partitions
1024+0 records in
1024+0 records out
1048576 bytes (1.0 MB) copied, 2.89689 s, 362 kB/s
Disk /dev/sdb doesn't contain a valid partition table
DISK SIZE - 3904897024 bytes
Checking that no-one is using this disk right now ...
OK
Disk /dev/sdb: 474 cylinders, 255 heads, 63 sectors/track
sfdisk: ERROR: sector 0 does not have an msdos signature
/dev/sdb: unrecognized partition table type
Old situation:
No partitions found
New situation:
Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/sdb1 * 0+ 8 9- 72261 c W95 FAT32 (LBA)
/dev/sdb2 10 473 464 3727080 83 Linux
/dev/sdb3 0 - 0 0 0 Empty
/dev/sdb4 0 - 0 0 0 Empty
Successfully wrote the new partition table
Re-reading the partition table ...
If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes: dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
Partitioning Boot
mkfs.vfat 3.0.7 (24 Dec 2009)
Partitioning rootfs
mke2fs 1.41.11 (14-Mar-2010)
Filesystem label=rootfs
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
233392 inodes, 931770 blocks
46588 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=956301312
29 block groups
32768 blocks per group, 32768 fragments per group
8048 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 31 mounts or
180 days, whichever comes first. Use tune2fs -c or -i to override.
Partitioning is now done
Continue to install filesystem or select 'n' to safe exit
**Warning** Continuing will erase files any files in the partitions
Would you like to continue? [y/n] : y
Mount the partitions
Emptying partitions
Syncing....
Choose file path to install from
1 ) Install pre-built images from SDK
2 ) Enter in custom boot and rootfs file paths
Choose now [1/2] : 1
Will now install from SDK pre-built images
now installing: ti-sdk-am335x-evm-05.04.01.00
Copying files now... will take minutes
Copying boot partition
MLO copied
u-boot.bin file not found
u-boot.img copied
uImage copied
Copying rootfs System partition
Written 100%
Syncing...
Un-mount the partitions
Remove created temp directories
Operation Finished
